03 wrx AEM + TBE - Subaru WRX Forum
post #1 of 14 Old 06-05-2013, 07:11 PM Thread Starter
BigDaddyFrost is an unknown
03 wrx AEM + TBE
I have 03 WRX with AEM cai + tbe. Is the cobb off the shelf tune for use with the SF intake really that much different than if I was using the cobb intake?
BigDaddyFrost is offline
post #2 of 14 Old 06-05-2013, 07:15 PM
Yes. Stick to the map notes.... don't stray from them.
post #3 of 14 Old 06-05-2013, 07:32 PM Thread Starter
there's that much difference between the intakes?
post #4 of 14 Old 06-06-2013, 05:47 AM
COBB seems to think so.
post #5 of 14 Old 06-06-2013, 07:09 AM
There is a difference in intakes. The curve after the MAF is the difference. It looks small, but that changes all sorts of parameters..
post #6 of 14 Old 06-06-2013, 08:00 AM
I'm pretty sure the air diverter is different as well. Maybe even the MAF location.
post #7 of 14 Old 06-06-2013, 01:07 PM
I'm just pulling from memory, but you might be right about the MAF location.
post #8 of 14 Old 06-06-2013, 01:32 PM Thread Starter
I guess I'll just have to get it pro tuned instead of using the ap
post #9 of 14 Old 06-06-2013, 02:59 PM
You should anyways.
post #10 of 14 Old 06-06-2013, 03:29 PM
You have to get an AP to get protuned.
post #11 of 14 Old 06-06-2013, 05:06 PM
Unless he doesn't have an AP and wants to get tuned via OpenSource..... which I don't think you should do.
post #12 of 14 Old 06-06-2013, 06:15 PM Thread Starter
I don't have an AP, but was considering getting one to put a tune on the car. I have the stock airbox on atm, not going to install the aem until I plan on getting it tuned. Just wanted to see what was the best route to go.
post #13 of 14 Old 06-06-2013, 06:40 PM
If in doubt, get the AP and take a few 3rd gear logs with the stock airbox... then install the AEM and do a few 3rd gear pulls.... post em.
cake bro
post #14 of 14 Old 06-07-2013, 01:01 PM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
The Cobb SF intake has a "MAF Straightening" Effect. From My understanding it "smooths out" the airflow readings that the ECU gets in order to run more precisely.
The AEM intake does not have this same effect and people have said that the tune for the SF intake will not run correctly as a result.
The Cobb SF intake is actually really inexpensive, so if you want to use that tune you could just pick up the right intake.
We carry them on our website here:
2003 Subaru Impreza 4 Door Sedan WRX COBB Tuning SF Intake System
PRO Import Tuners
PROImportTuners is offline
