Old 12-26-2002, 07:48 PM   #1 (permalink)
Reputation: matt d is an unknown
Talking wrx short throw shifter. Should it rattle?
I just recently purchased a wrx sportwagon with the short throw shifter. I've noticed that the shifter vibrates alot and makes a pretty loud rattling noise. I was wondering if this was normal for this shifter and if anyone else has experienced this. The dealership says it is normal, but I don't know if i believe them. IF so what is the reason for it.
Old 12-29-2002, 11:38 PM   #2 (permalink)
Reputation: WagonRex is an unknown
The short-shifter does seem to transmit more noise.
I haven't noticed any unusual vibration though.......or any loud rattling.
Might be something loose in there , you should INSIST on them checking it.
However , I'm used to driving race type cars , where vibration and noise is normal , in fact this car is MUCH too quiet for my taste
Old 01-01-2003, 11:45 PM   #3 (permalink)
latinWRX's Avatar
Reputation: latinWRX is an unknown
I can't compare w/ the normal shifter cause mine came stock w/ the short shifter, but it does seem to rattle a tad. Though it depends cause mine doesn't rattle (or I don't feel it) at high speeds; just when I'm idle.
"Many people have a good aim in life; most never pull the trigger."
Old 01-03-2003, 07:20 PM   #4 (permalink)
mikeWRX's Avatar
Reputation: mikeWRX is an unknown
It shouldn't rattle. The gear shift rod is probably hitting the front of the baseplate a little in a certain gear. Does it rattle in all gears or just 1st, 3rd and 5th? Mine did this too until I loosened the screws on the baseplate and shifted it a little. It does vibrate more though.
Old 02-25-2003, 05:28 PM   #5 (permalink)
Subie Gal's Avatar
Reputation: Subie Gal is an unknown
there's a slight vibration in mine...
but no noise... that doesnt seem quite right to me??
i'd make em look at it....
Jamie
[webpage] [posts] Reply With Quote
Old 03-02-2003, 05:05 PM   #6 (permalink)
Reputation: 4WDrift is an unknown
Mine also vibrated, I did the baseplate shift and its gone(thanks mikewrx). I could actually hear it under the car on mine.
