WRX 06 TRANSMISSION INTO 02 ?? 5 speed - Subaru WRX Forum
post #1 of 12 Old 09-02-2009, 04:34 PM Thread Starter
theorb13's Avatar
theorb13 is an unknown
Guys im getting ready to buy a transmission, and i am being told that since my car is a 02 wrx, that i would need to replace my rear differential for an 06 differential. is any one aware of this ? thanx guys
theorb13 is offline
post #2 of 12 Old 09-02-2009, 04:37 PM
I don't think you have to... I don't see why. I thought the 06 had the same rear diff as the earlier years? Thus why everyone was breaking them on the 06 thanks to the EJ255's torque upgrade over the EJ205...
post #3 of 12 Old 09-02-2009, 05:08 PM
i'm pretty sure they are the same....
post #4 of 12 Old 09-02-2009, 08:54 PM Thread Starter
theorb13's Avatar
Thats what i thought, but the person that i am buying it from assures me that i will need it, he is a suby tuner..in ny , does any one know for sure ?? thanx guys
theorb13 is offline
post #5 of 12 Old 09-02-2009, 08:58 PM
Maybe he's talking about the front diff? Did you break more than just your gears?
post #6 of 12 Old 09-02-2009, 10:06 PM Thread Starter
theorb13's Avatar
only first gear is blown everything else seems fine...
theorb13 is offline
post #7 of 12 Old 09-03-2009, 11:26 AM
The rear diff is completely separate from the trasmission and basically identical at least 02-06. Unless he was talking about something else, I think he's mistaken.
post #8 of 12 Old 09-03-2009, 01:21 PM Thread Starter
theorb13's Avatar
i was under the same impression...that the diffrential was always the same on all wrx from 02-07
theorb13 is offline
post #9 of 12 Old 09-04-2009, 12:43 AM
The diff will not be your issue. You are buying a transmission that is set up for a different clutch type. In 06 they changed the clutch to a push type clutch. All the prior WRX's were a pull type clutch. You will need more than just the tranny to make it work in your car.
Kjott21 is offline
post #10 of 12 Old 09-04-2009, 10:19 AM
^ Interesting, I didn't know that.
post #11 of 12 Old 09-04-2009, 11:53 PM Thread Starter
theorb13's Avatar
thanks alot dude!...i decided against it because it does seem like to many variables..lol i just want a direct bolt on replacement to mined with BA gears....will the late 04-05 transmission bolt right up ? or will i need to find Axle Stubs also..
as per this site
Millennium Auto -Specializing in Subaru WRX STI
theorb13 is offline
post #12 of 12 Old 09-05-2009, 12:13 AM
as per this site
04/05 tranny you should just be able to bolt right up.
Kjott21 is offline
