Old 03-26-2009, 09:54 PM   #1 (permalink)
Club Region: Southeast
Reputation: basco is known to be trustworthy and helpful basco is known to be trustworthy and helpful
Will a WRX clutch and flywheel work on a EJ257
Ok so here it goes...about 2 months ago I just had my EJ207 rebuilt and a new clutch and flywheel installed...but about 2 weeks ago it started acting funny and I just got it torn apart yesterday and the oil pump had failed which caused low lubrication and basically destroyed the motor...so now I found a guy selling a new 2.5 shortblock at a good price so I'm gonna buy that and build a hybrid...but I was wondering will my clutch and flywheel work with the 257 and my WRX 5-speed???
Proud Pilot of FP Green powered Grocery Getter and Stage II Evo VII daily driver
BaScO aka Matt
Old 03-26-2009, 10:24 PM   #2 (permalink)
c2bcoolwrx's Avatar
Car: 05 WRX
Reputation: c2bcoolwrx is more helpful than not
Yes, they will. I am running that hybrid setup (EJ257 w/EJ205 Heads, 5-speed, etc).
Old 03-26-2009, 10:37 PM   #3 (permalink)
cool...but will my flywheel be too light I have the gruppe-s lightened flywheel for the WRX and I noticed the one they sell for the STi is 1lb. heavier
BaScO aka Matt
Old 03-27-2009, 12:47 AM   #4 (permalink)
c2bcoolwrx's Avatar
Car: 05 WRX
Nope it should be fine.
As long as the flywheel is over 12lbs usually not a problem (general rule of thumb). Are you doing the build yourself? B/c if your having it built that is something you should discuss with your builder. Also a hybrid build is not just a simple plug and play there are many things to consider/parts needed such as:
Compression - What headgasket are you using? (i.e. Cosworth, Cosmetic, STi/OEM)
Various Gaskets - Get a set
shims/buckets or bucketless shims (depending on the year of the small block)
12mm or Sti Oil Pump
Water Pump
New Timing Belt & other belts (depending on age/milegage)
New Head Studs (i.e. ARP)
Good Tune from an experienced tuner
Old 03-27-2009, 03:41 AM   #5 (permalink)
Reputation: Chase is known to be trustworthy and helpful Chase is known to be trustworthy and helpful Chase is known to be trustworthy and helpful
I have an extra set of ARP studs, pm if interested, I'm so sorry to hear you had to tear it apart dude. I hope for 100k before I tear mine apart again. You just got it back... sorry man.
And I reused my water and oil pump. Working fine.
Stage 2 Cobb OTS map 2004 STi
Soon to be Stage 1 2001 Corvette
Old 03-27-2009, 06:59 AM   #6 (permalink)
Water Pump
Idk what head gasket I'm using...I havent really gotten that far...but probably a Cosworth...any recomendations on thickness
Shims????
what do u mean 12mm is that the pickup for the oil pump
I should me able to re-use my water pump from the 207 seeing as it was brand new right?
same with the belts?
and Gadiel Tuning will be tuning the car
BaScO aka Matt
Old 03-27-2009, 08:56 AM   #7 (permalink)
Trader Rating: (3)
Yes, as said before the WRX clutch/flywheel will work with the 2.5L block.. The Transmission is what you match the clutch to, not the block. If you drop in an STI 6 speed you will need an STI clucth/flywheel setup..
Old 03-27-2009, 11:10 AM   #8 (permalink)
Cometic .051 is what I'm running in my hybrid
And I would use the pump if it's compatable, but I wouldn't cheap out on the belts. Those things are like $20 for the accessory belts and 100 for a really good timing belt from gatesracing.com. I'm not even sure it'd fit.
Not to be a self promoting blowhard, but I compiled some stuff after my hybrid build that might help you:Hybrid build/rebuild info
And are you tearing that block down to do pistons and bearings? I didn't do forged rods since I'd never heard anyone say they were a problem, but I'd recommend forged pistons. It really not that hard when Your this far in.
Old 03-27-2009, 01:13 PM   #9 (permalink)
the only reason im willing to re-use the belts is because the motor only had 1300 miles on it...but yeah im tearing the block down to upgrade the bearings and it already has CP forged pistons in it...I just dont have the money for rods right now so they'll have to wait
BaScO aka Matt
Old 03-27-2009, 02:10 PM   #10 (permalink)
c2bcoolwrx's Avatar
Car: 05 WRX
+1 good advice. I agree definitely go with some forged pistions (i.e. CP). My headgasket is a Cosworth gasket (cannot remember the thinkness, but it was the one Cosworth recommended for hybrid builds using the 2.0L/EJ205 heads).
Old 03-27-2009, 02:14 PM   #11 (permalink)
c2bcoolwrx's Avatar
Car: 05 WRX
Shims????
The shims are for the valvetrain. You have to the measure clearences a replace the shims accordingly (check and set the valve lash and buying new shims and/or moving some from valve to valve). There are 16 shims in all, but generally you can reuse some of your current shims. You can purchase new shims from your dealer (make sure to get the correct shims for the year of your EJ257, b/c the older ones use the shims w/buckets and the new ones use shimless buckets or bucketless shims, whatever they are called).
