I will be having Northwest performance changing out my clutch I was thinking OEM but my friend said to look at an aftermarket but my car is a daily driver and not sure if I go with aftermarket drivability will go down.
any suggestions will help me alot
thanks Dan
2005 WRX
Borla XR-1 CBE Best Purchase so far
After looking at your profile and seeing no mods listed for your car the rule of thumb expressed in numerous threads regarding purchasing and installing an aftermarket clutch is STOCK WRX TRANSMISSION = STOCK OEM CLUTCH.
well i have an exedy stage 1 organic on my stock tranny and i like the extra little bit of hold it gives...but i also have too much power that i shred stock clutches in a couple of weeks
Proud Pilot of FP Green powered Grocery Getter and Stage II Evo VII daily driver
BaScO aka Matt
If your transmission is still stock, get another stock clutch. You want the clutch to be your drivetrain "fuse" in case anything should go horribly wrong. It's much less expensive to get another clutch than a partial or completely new transmission.
2007 WRX Limited Sedan
Cobb AP Stage 2
sorry mind is fried from auto electic class
ok here gos
when your driving and your coming to a stop sign do you shift into N and aply the brakes or down shift from lets say 4th to 3rd and let the engine and drivetran do the work
because I shift into N and use the Brakes that way the trans and drivetran dont take the shock
a guess Im just wondering
2005 WRX
I run down the gears. I really dont always trust people that drive. That way if something happens and its possible for me to move or get out of the way i can.
Hi all, I'm interested in clutch advice too. Just got an 02 wagon. All parts stock. Clutch will be a necessary first mod, and I don't want to cut short on future upgrades while I've got it open. This will be an aggressive DD and probably Rally-Xer.
As a newbie, I have to ask, what is Stage II? Is this the clutch level I want? Is Exedy standard, midgrade, or high performance brand?
Danielson,
Slowing down (at any speed) equals downshifting, unless you are trying to save gas by coasting. This will not hurt your tranny as long as you rev match properly. This is not synonymous with engine braking, which I do not recommend. Using the engine to slow down has few if any advantages, doesn't save gas, and generally deteriorates from competitive technique. Further, when done improperly, engine braking can cause transmission stress/damage.
Remember gone in 60 seconds? I think Nick Cage gives a good lesson to his gokart students. The name of the game is to be smooth. And prepared. So rev match for smooth transition, and downshift in preparation for your exit (of turn, stoplight, traffic, etc.).
Danielson,
Sounds good never thought of it that way and I like that used gone in 60 seconds!
also I went with a Clutch and flywheel combo from ACT and Ian noticed that the dust boots on my front axles are torn so hes replacing them so about a whole week I wont have my car
The Clutch is Stage I oem from ACT and the flywheel is a Streetlight from ACT
cant wait to get my car back and hear thatboxer rumble through my Borla XR-1 CBE
2005 WRX
