-   -   Turbo and Transmission swap (http://www.wrxtuners.com/forums/f69/turbo-transmission-swap-39745/)
Subazda 09-29-2013 06:29 AM
i am not sure that i chose the right section for my thread (hope it is) , so anyway , i own a 2005 TS and plan on swapping a WRX Engine with a STI Tranny , but i have some questions before getting to buy anything
i plan on a VF48 with an EWG for the JDM EJ205 i will get , as i heard from some people it's not possible to make such a swap without a standalone ECU since that the JDM ECU's cant be tuned , is it true ? :confused:
also about the STI trans. swap , it will be a 2005 STI transmission with the differential , hubs , axles , Control units , will i face any problems fitting it to the VF48 JDM EJ205 ? and also was planning to fit a Big brake system since i wont be getting the brembo's , is there any difference between the USDM and the JDM Spindles ? , also for the coilovers , is there any difference between the USDM and the JDM suspension ?.
brfatal 09-29-2013 10:36 AM
JDM ecu is tunable. And the turbo has nothing to do with trans fitment.
psinuse 09-29-2013 11:11 AM
You can buy a complete STi clip with motor and trans. It would have what you'd need to do the motor and trans swap. I'd use the EJ207 long before using the EJ205.
brfatal 09-29-2013 11:37 AM
JDM EJ205 is not the same as the USDM one. Higher compression and AVCS.
Subazda 09-29-2013 02:15 PM
[quote=psinuse;362417]You can buy a complete STi clip with motor and trans. It would have what you'd need to do the motor and trans swap. I'd use the EJ207 long before using the EJ205.[/quote]
the sti service will be alot more expensive , also no spare parts for it where i live .
Subazda 09-29-2013 02:17 PM
[quote=brfatal;362425]JDM EJ205 is not the same as the USDM one. Higher compression and AVCS.[/quote]
will it affect the sti trans swap ? or the VF48 swap ?
Subazda 09-29-2013 02:19 PM
[quote=brfatal;362409]JDM ecu is tunable. And the turbo has nothing to do with trans fitment.[/quote]
what about the 16bit and the 32bit thing ? also will i face any problems when i buy normal parts for the car that requires getting a tune such as FMIC , Water Meth Injection ,etc. ?
brfatal 09-29-2013 05:37 PM
[quote=Subazda;362465]what about the 16bit and the 32bit thing ? also will i face any problems when i buy normal parts for the car that requires getting a tune such as FMIC , Water Meth Injection ,etc. ?[/quote]
You're gonna need a JDM WRX ECU to run this motor. And of course it will require a tune.
turmic 09-29-2013 08:42 PM
Justin, you're being patient...I'm confused. Lol ;)
BLAZE2099 09-29-2013 08:49 PM
He gets nicer when it's his time of the month Kirt... Hahaha
I had too
Subazda 09-30-2013 06:27 AM
[quote=brfatal;362537]You're gonna need a JDM WRX ECU to run this motor. And of course it will require a tune.[/quote]
i am aware of that , what i meant to say that i heard from a guy with a JDM WRX that the JDM ECU is not fully tuneable like the USDM is that right ? also is there any difference in the suspension between the JDM and the USDM ?
turmic 09-30-2013 08:55 AM
Why wouldn't it be tuneable? Just need to figure out which EM works with the JDM ECU and hope it has a language selection other than Japanese.
LW_Black4 09-30-2013 12:35 PM
[quote=psinuse;362417]I'd use the EJ207 long before using the EJ205.[/quote]
Here's a link:
[B]EJ207[/B]
[URL="http://www.wrxtuners.com/forums/f52/ej207-20865/"]http://www.wrxtuners.com/forums/f52/ej207-20865/[/URL]
Used in the Impreza WRX STi 1998~present (JDM, specifically Homologation models for World Rally Championship) [Wikipedia]
turmic 09-30-2013 12:51 PM
[quote=LW_Black4;363057]Here's a link:
[B]EJ207[/B]
Used in the Impreza WRX STi 1998~present (JDM, specifically Homologation models for World Rally Championship) [Wikipedia][/quote]
Keith's kind of a expert in the 2.0 L game Laszlo. I think he knows what a EJ207 is. ;)
LW_Black4 09-30-2013 02:14 PM
[quote=turmic;363089]Keith's kind of a expert in the 2.0 L game Laszlo. I think he knows what a EJ207 is. ;)[/quote]
Certainly, but Subazda may not be. :)
