transmission fluid - Subaru WRX Forum
post #1 of 30 Old 05-15-2011, 06:27 PM Thread Starter
transmission fluid
i have an 05 wrx and need to change my manual transmission fluid i have heard alot about "the andrewtech coctail"fluid what are some opions on this and has anybody have any problems with this. i also heard that motul 300 full synthtic is a good fluid. any input will help. thank you
WRbluewrx is offline
post #2 of 30 Old 05-15-2011, 11:15 PM
Andrewtech uses Motul.
post #3 of 30 Old 05-16-2011, 05:45 AM
Get the Subie "S" stuff.... Just change it out every 30K
post #4 of 30 Old 05-16-2011, 05:57 AM Thread Starter
i heard autowretch uses 1 quart motul 300 and 3 quarts redline. and were would i find subie "s" stuff online or have to go to a dealership
post #5 of 30 Old 05-16-2011, 09:49 AM
I have an 07 WRX with a stock 5 speed manual transmission and I've used:
0-3k = Whatever fluid came in it from the factory
3k-30k = Redline 75W-90 NS
30k-60k = Redline 75W-90 NS
60k-83k (present) = Andrewtech Cocktail
I plan on using the Andrewtech Cocktail again when I change the trans fluid at 90k and every 30k after that for the forseeable future. I didn't really notice any specific differences between the fluids besides that the car shifted like butter immediately after it was changed. If the cocktail wasn't so expensive, I'd seriously consider changing the trans fluid every 20k or sooner instead of every 30k like it's suggested in the factory maintenance schedule.
FYI - The Andrewtech Cocktail is:
(1x) 1 Liter Motul Gear 300 75W-90
(3x) 1 Quart Redline Lightweight Shockproof Gear Oil 75W-140
post #6 of 30 Old 05-16-2011, 11:29 AM
Dealership will have the S stuff. You need to bring a container (they usually on sell it by the 5 gal drum).
post #7 of 30 Old 05-16-2011, 11:51 AM
With the andrewtech make sure you put the whole litre of Motul in first then top it off with the redline, it won't take all three quarts put two in then keep checking and after you test drive it top it off again and your good to go.
And Paul not all of the Dealerships carry the S stuff and most that do will only sell it to you by the 5 gal container.
post #8 of 30 Old 05-16-2011, 12:33 PM
^ Good call Matt. I always forget to mention that part
post #9 of 30 Old 05-16-2011, 12:48 PM
From when I bought it (2008), the service mgr said something to the effect of "since that's all we are supposed to put in the cars now, we have to have it on hand".
Makes sense.... Bet these dealers are feeding ppl a line of BS if they say they don't have it. That or they have crappy customer service.
I'll take the latter of the 2.
post #10 of 30 Old 05-16-2011, 07:41 PM Thread Starter
thanks guys for information im going to go with the andrewtech cocktail. and for the t-70 torx bit for the tranny ill prob have to special order that online or would a local autoshop carry that thanks again.
post #11 of 30 Old 05-17-2011, 05:52 AM
Local shop will have the torx.... If not one...another should.
post #12 of 30 Old 05-19-2011, 12:54 PM
I found my T-70 Torx bit on the shelf at a local auto parts store - can't remember which one (most likely Auto Zone, Advance Auto, or Pep Boys)
post #13 of 30 Old 05-23-2011, 05:23 PM
c2bcoolwrx's Avatar
I personally use Motul Gear 300 and my tranny loves it.
c2bcoolwrx is offline
post #14 of 30 Old 06-08-2011, 02:39 PM
rotheee's Avatar
I just received my tranny cocktail from GrimmSpeed. Waiting for my Brand new Fidanza V1 Clutch to arrive before i put it in.
Package includes:
1 Pennzoil Synchromesh Quart
2 Castrol Hypoy C 80w90
1 Redline Lightweight Shockproof
rotheee is offline
post #15 of 30 Old 06-10-2011, 01:44 PM
That is all.
