Transfer case reseal and new bearings - Subaru WRX Forum
post #1 of 9 Old 06-18-2011, 10:45 PM Thread Starter
wagonracer's Avatar
So I finally got around to replacing the shift shaft and rear (yolk) seals on my tranny today. While I was in there, I felt and listened to the viscous coupler and rear output shaft bearings. I decided that since it was apart, I should git 'er dun. (182K on trans.) It wasn't too bad of a job, and the noise I had gotten used to for the last couple of years on decel in third and fourth (mostly) is gone ! It also feels good knowing that they are new, since I've seen them fail completely on other Subie 5 speeds.
I will post up more details of what I'm talking about (sorry, forgot to take a camera with me) if anybody shows an interest in learning more.
Cullen
wagonracer is offline
post #2 of 9 Old 06-18-2011, 11:35 PM
Cullen, what type of noise were you hearing? Just curious to learn and understand some more stuff about the car.
post #3 of 9 Old 06-19-2011, 11:58 AM
Sure, I don't own a 5 spd. But, I am always curious to learn more.
Last edited by turmic; 06-20-2011 at 02:49 PM. Reason: Just wish I could spell at times...lol
post #4 of 9 Old 06-19-2011, 09:13 PM
...as am I.
post #5 of 9 Old 06-20-2011, 06:04 PM Thread Starter
wagonracer's Avatar
I am ready to share more info, which will be much easier with some illustrations, but for some reason there is no "insert image" icon here today. Any idea why not ?
The noise was kind of a deep scraping sound under decel only, heard coming from the tunnel. I used to think it was my clutch release bearing rattling on the tranny shaft. After installing a sleeve kit it still persisted. Must have been one of the transfer case bearings.
Cullen
post #6 of 9 Old 06-20-2011, 06:24 PM Thread Starter
wagonracer's Avatar
Name:  transfer case diagram.jpg
I guess I can add the image as an attachment, after saving it to my 'puter.
So, what I replaced were the seal # G73521 and the shift shaft seal (not pictured) Once in there and after inspection I also replaced bearings G33008, G32204, and G23017. They should probably be removed and installed from their respective shafts with a hydraulic press, but since we shockingly don't have one at the shop, were fairly easily done with a vise and a BFH. The one right next to the coupler gear (G33008) had to be hacked off with an angle grinder and chisel. The whole operation was performed by removing the back of the case (32130 in the diagram) BTW, 38913 is the viscous coupler.
First the driveshaft had to be removed and the roll pin for the shift shaft punched out. That was a bit of a biatch, as it's actually two different pins, one inside the other. After performing the work inside the case, the plate on the back is just bolted back on with "Fuji-Bond" and everything else just re-installed.
I would not recommend this job as a driveway task on jack stands, but it certainly is possible. I was very glad to be able to use a lift.
Cullen
post #7 of 9 Old 06-21-2011, 01:30 PM
BFH does that equal Big Freakin' Hammer?
post #8 of 9 Old 06-21-2011, 01:43 PM Thread Starter
wagonracer's Avatar
Correct sir
Cullen
post #9 of 9 Old 06-21-2011, 01:54 PM
Score! I know all those days of playing Doom would pay off in the end.
