Tips before I mount engine back to trans. - Subaru WRX Forum
 2Likes
  • 1 Post By BLAZE2099
  • 1 Post By AllExtinct
post #1 of 8 Old 08-19-2014, 11:59 AM Thread Starter
AllExtinct's Avatar
Well it's almost that time and I was looking for any tips on how to make this go as smooth as it came out "hopefully".
I plan on putting a small amount of grease on clutch fork and pivot point, already have the throw out bearing seprated from the pressure plate to do the push connection with the fork once the trans meets with the engine.
I noticed the throw out bearing seems a bit dry sounding can I spray lithium grease or something on it or just leave it?
Also going to put a bit of grease on the shaft.
When mounting the trans to engine, gonna try to go for the way I got it out by having the trans jacked up at a angle.
Anyone have any pointers or tips to share before I wrestle the soul back into the beast.?
Thanks.
AllExtinct is offline
post #2 of 8 Old 08-19-2014, 11:13 PM
Through the top or bottom?
I've done a billion both ways, just go really slow and take your time.... Very slow going in, it's like losing your engine virginity.
Epictofer likes this.
post #3 of 8 Old 08-19-2014, 11:35 PM
Brockton's Avatar
It helps if loosen the mounts and jack up the rear of the motor a bit so its slightly angles. It helps the tranny go back on much smoother.
Brockton is offline
post #4 of 8 Old 08-20-2014, 07:05 AM Thread Starter
AllExtinct's Avatar
The transmission is still in the car im just dropping the engine in.
It came apart like sliced butter pretty much compaired to other stories where people has to use pry bars to separate the 2.
I was gonna try lining the 2 studs on the bottom of the block and slide it in from an angle like you said brock, I have the trans set up the same way atm the same way it was removed.
Any info on if I can spray a small amount of lithium grease on the TOB or not. I dont wanna mess with it if it could cause failure of the clutch.
Only sparingly greased the clutch fork as of right now.
Also shiuld I try to clean the pressure plate with anything if so what, brake cleaner?
Really want to make this a one time deal so trying to the best out of it.
post #5 of 8 Old 08-20-2014, 03:21 PM
LW_Black4's Avatar
Installation from the '04 WRX Service Manual:
http://i.imgur.com/FLb1E6U.png
http://i.imgur.com/vfWtxTn.png
Laszlo - white '11 STi sedan
LW_Black4 is offline
post #6 of 8 Old 08-20-2014, 08:03 PM Thread Starter
AllExtinct's Avatar
Sweet ,thanks man!
post #7 of 8 Old 10-23-2014, 01:38 AM
s202 is an unknown
Works in both WRX and STi, followed this video when I did mine, made things a little more reassuring and simple upon install.
Other than don't angle or let the input shaft 'hang' on the clutch mounted to the engine(as indicated even on the exedy blutch/pressure plate box), its pretty straight forward.
http://www.exedyusa.com/multimedia/s...structions.pdf
https://www.youtube.com/watch?v=-NAxb_uU1Ys
s202 is offline
post #8 of 8 Old 10-23-2014, 11:49 AM Thread Starter
AllExtinct's Avatar
I actually ended up putting the engine by myself just set the cherry picker to a really slow drop and Bing,Bang,Boom everything went together like peanut butter and jelly. :-P
