sti transmission for my wrx - Subaru WRX Forum
post #1 of 6 Old 09-17-2004, 03:45 PM Thread Starter
eighth08's Avatar
eighth08 is more helpful than not
Send a message via AIM to eighth08
As some of you may know my transmission broke on my wrx the 3rd day i had it (got it brand new) im not getting into that.. but i was thinking.. i need to replace my entire transmission... would anyone suggest putting in the STI 6 speed if it will work? i figure its gotta be a little more beefed up in strength since it is designed for a 300hp sti. also i think the 6speed aspect would be really cool.
any thoughts?
-greg
Gregory-
keep it in the dirt.
eighth08 is offline
post #2 of 6 Old 09-17-2004, 03:55 PM
Subie Gal's Avatar
Subie Gal is an unknown
Red face
adding the 6 speed mt...
wouldnt you also need to change the driveshaft?
and wouldnt that, in turn, require a different rear diff?
and wouldn't THAT also mean different rear axles and hubs??? !Cry!
seriously...
you will need at a minimum:
Tranny, sti clutch and flywheel, shortened stock driveshaft, shifter, shift boot, shift knob, 3.90 ring and pinion.
Other Recommended items:
DCCD controller, STi front axles and hubs, Complete STi R180 rear end with axles, hubs and R180 diff.
www.rallispec.com is the place to check it out.
and yes.. it's all been done already
Jamie
Subie Gal is offline
post #3 of 6 Old 09-17-2004, 05:26 PM
IBAUCLAPlaya's Avatar
Yeah it requires a lot of money and work. Godspeed does it installed for 5 grand. Not bad.
IBAUCLAPlaya is offline
post #4 of 6 Old 09-18-2004, 01:29 PM
Cosmo's Avatar
Images: 15
5 grand is about half what I've seen most places. The transmission alone is close to that.
Cosmo is offline
post #5 of 6 Old 09-18-2004, 03:44 PM
tescrex's Avatar
tescrex is an unknown
Send a message via AIM to tescrex
I'd reccomend getting a beefed up set of new gears. A lot of people like the V7 sti gearset.
tescrex is offline
post #6 of 6 Old 09-19-2004, 06:52 AM
WRXtreme's Avatar
I have heard that the gears are not the weak part of the WRX transmission, but the trans case itself. I think the trans case is two peice and during hard driving it expands/flexs allowing the the gears to seperate and then come back together in turn sheering off teeth. The STi along with being stronger in most aspects has a one peice trans case taking care of the problem. I think what I would do would be to make/buy a trans brace if their is such a thing. And if there is such a thing, please link the product so I can check it out as well.
WRXtreme is offline
