sti tranny in 03 wrx - Subaru WRX Forum
post #1 of 6 Old 08-22-2007, 10:38 PM Thread Starter
akwrx's Avatar
akwrx is an unknown
well im trying to get all the parts figured out and mostly have it but i have a question about the hubs. Its an 05 transmission, would 04 sti hubs work with that? and with the 04 hubs would i be able to keep my stock wrx brakes or would i have to get the brembos?
akwrx is offline
post #2 of 6 Old 08-23-2007, 11:43 AM
no the WRX breaks won't fit on the STi hubs.
Take a few hundred steps back though, what are you trying to do? The STi's 6-speed is an expensive and silly swap into a WRX. You're much better off with a PPG or other 5-speed swap. They're stronger, cheaper, and don't require you to replace the whole rear end of your car!
post #3 of 6 Old 08-23-2007, 12:12 PM
thebean123's Avatar
thebean123 is an unknown
Ya, you definitely need to go with the brembo's, sorry. Dude dont listen to him though go for the 6 speed swap, that will sperate you from the PPG and cryogenic interals crowd. +1 for Akwrx for even attepmting to do this swap. Go for it!
thebean123 is offline
post #4 of 6 Old 08-23-2007, 01:57 PM
mystilexzero is an unknown
i want a 6 speed =( but then again it really depends on what kind of driving you do, can anyone clear this up for me will a 6 speed get to its top end faster than a 5 speed?
mystilexzero is offline
post #5 of 6 Old 08-23-2007, 03:47 PM
no, it's a crap tranny for drag racing. WORSE than the WRX's 5-speed. It is however a bit stronger (but if you want strength get a PPG 5-speed). It's ultra close and 6th is actually tighter than 5th on the WRX tranny! It will actually reduce your quarter mile times. It's not geared for drag racing AT ALL.
post #6 of 6 Old 08-29-2007, 10:23 PM
bigwem is an unknown
I agree that the 5spd is faster I'm right at the same power level as a sti and the 5 speed helps ALOT!
its all about the 3rd and 4th gears plus I think the 6 speed hits top of 4th just short of the 1320 mark so going to 5th right at the end can't be good.
bigwem is offline
