short shifter blues - Subaru WRX Forum
post #1 of 8 Old 12-03-2004, 12:18 AM Thread Starter
nocsyn@templ is an unknown
short shifter blues
yo everyone my friend owns a 02 wrx and i was tryin to install the b&m short throw on his car....was doin pretty good until i got to the o ring.....got the tool for it....bam problem...how the fock do u get to the damn thing with the driveshaft in the way?...i didnt remove the heatshield bc i was lazy but i still dont see how i could get in there wit the tool....especially im thinkin later on how im supposed to put the damn thing back together....any help would be great....btw for people who have done this, is this the hardest part?? what other problems might lie down the road in the future?
nocsyn@templ is offline
post #2 of 8 Old 12-03-2004, 02:15 AM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
What are you talking about?
1. Please using punctuation to make it easier on everyone.
2. Changing the short shifter consists of using a 14mm wrench to remove the bolts.
3. Take out the screw.
4. Bend shifter all the way back in one direction and give it a nudge with a mallot and it will come out.
5. Take out the things in the old shifter and put them in the new one.
6. Apply some white grease to the shifter at the bottom and the socket where it get seated.
7. Align it.
8. Hit it down with something that has momentum.
9. Tighten it up.
10. You're done.
What heatshield are you talking about?
Che
Tut4u2 is offline
post #3 of 8 Old 12-03-2004, 02:00 PM Thread Starter
the directions straight from b&m tell us to go underneath the car and open up the o ring and supposedly (im guessing here) it comes right out.
the exhaust heat shield is what they tell us to remove to get to it, but still the driveshaft is in the way.
so im confused ## telling me one thing but the directions say another....thx for at least responding tho
post #4 of 8 Old 12-03-2004, 07:55 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
I had a simular problem with that o-ring it was a ##### to get to, you might want to try useing a screw driver to remove it with the o-ring tool. You might have to heat up the o-ring tool and bend it to fit easier and have someone sit inside the car and push down on the shifter or the shifter will keep moving on you. Every thing else was pretty easy but the p-ring is a pain in the ass to get back on. I think the heat sheild is to another model car. good luck
Ian is offline
post #5 of 8 Old 12-04-2004, 10:51 AM Thread Starter
thx man i appreciate the info. im thinkin about actually headin down to the dealership to see the exact oring tool they use cause i dont feel like doin this crap much longer
its very cold outside thx again tho...btw were u using a bent oring tool (i forget the exact name) cause we were tryin wit that but we also had a straight one. im just curious...pc
post #6 of 8 Old 12-04-2004, 12:16 PM
Ian
Ian's Avatar
I was useing this old peace of crap one that has changable pins that I couldn't tighten so it kept moving on me luckly I have a lift at work wich helped but still a ##### to get that little ring on
Ian is offline
post #7 of 8 Old 12-04-2004, 10:30 PM
Are you guys talking about the shifter bushing under the car, next to the tranny?
post #8 of 8 Old 12-05-2004, 02:47 AM Thread Starter
yea its the o-ring....anyways i wanted to update u guys on my boys rix....ok so instead of going underneath the car we got pissed....pulled the shifter out in like two tries (actually my boy did i was a t work..boo)
he said he was about to put the new one in but it would go..lubed and everything...he goes and buys a rubber mallet...doesnt do the trick....couple hours go by.....friends dad gets a block of wood and a hammer....smacks the shat out of it until it finally goes in....
long story short i drove it today and what a difference...awesome but def a pain in the ass he saved himself a couple bucks on the labor tho which is cool
