Shifter Wobble - Subaru WRX Forum
post #1 of 8 Old 07-03-2011, 07:23 PM Thread Starter
Msegars88 is an unknown
Shifter Wobble
Im new to WRX first off. 2002 WRX wagon
My shifter wobbles even when in gear. I was told I needed a new shifter bushing. I get under the car and the bushing is fine. was is loose is that linkage? yok? u-joint. whatever you want to call it right above the support bar that the bushings on are.
I dont think this bushing has anything to do with keeping it sable.
what do I need to order/where can i find it. Having a hard time even finding it online.
Msegars88 is offline
post #2 of 8 Old 07-03-2011, 07:25 PM Thread Starter
I stole this picture from another site. its that linkage right above the bushing and that support arm. that bushing itself was fine. And my layout is a little different then this. I dont have that cable there. nor is that bushing a stand alone in mine. It is attached to the tranny. I assume is a transmission support bar.
post #3 of 8 Old 07-04-2011, 01:49 PM
rex2002's Avatar
http://i61.photobucket.com/albums/h6...003/manual.jpg
mine is doing the same thing. the only thing i can think is that im missing the bushings that are highlighted in the picture in my link. do you have the bushings on your setup. the only other thing i could think to fix it was to put some plastic spacer washers where the shifter connects to the shift rod that comes inside the car
rex2002 is offline
post #4 of 8 Old 07-04-2011, 01:56 PM
rex2002's Avatar
btw i think the picture you posted was for the 6 speed tranny,the only difference is the reverse lock out cable the 5 speeds dont have that
rex2002 is offline
post #5 of 8 Old 07-04-2011, 09:59 PM Thread Starter
It was the shifter linkage. Turninconcepts.com has it for 80. Id get under there and have someone else wobble yours and see whats loose first.
post #6 of 8 Old 07-04-2011, 10:01 PM Thread Starter
And i knew the pic wasnt like mine. But it showed the two pieces i was talking about. The bushing vrs the linkage
post #7 of 8 Old 07-04-2011, 10:59 PM
wagonracer's Avatar
Way back when, I installed the cobb shifter bushing kit which replaces both the bushing pictured and the one above it (at the end of the shift lever) Well worth the money. I believe Kartboy sells a set these days to tighten things up. Easy install, should come with instructions.
Cullen
wagonracer is offline
post #8 of 8 Old 07-06-2011, 06:32 PM Thread Starter
This is what I got. Currently in the mail
TiC 5MT Linkage Update
2002 wrx
