-   -   Reverse grind- 2011 WRX (http://www.wrxtuners.com/forums/f69/reverse-grind-2011-wrx-39530/)
BLAZE2099 09-24-2013 06:26 AM
I'm having the problem of not being able to catch reverse from time to time. Than when I do, it grinds in. This is a bit upsetting and I was wondering if a good gear oil swap might be just what the doctor ordered.
Anybody else have this issue?
Anybody know of maybe a definite cause?
I typically only drive stick, so it's not me. My other two WRXs would do this once in a blue moon, but nothing to this extreme.
Thanks guys!!!
the RIOT act 09-24-2013 06:40 AM
I've googled it and read threads about this on all types of forums. Mine does it all the time too! Drives me nuts. I've read of people swapping fluid but had no success in making reverse catch better.
I simply put it in first and just barely let off the clutch (just to make the car move an inch or so) then go to reverse and it catches no problem. Def a ridiculous thing to have to do though....
arewmors 09-24-2013 06:56 AM
Mine does it if I'm going forward barely at a real slow roll and I try and go in reverse it grinds. Which makes sense I guess. So I always make sure I'm completely stopped. That's the only time I've experienced grinding
pzr2874 09-24-2013 07:21 AM
Only when cold Randy?
BLAZE2099 09-24-2013 08:53 AM
For the most part Paul, which makes sense.
I think a good ol fashioned cocktail may help.
Good call btw
Although my cars more than warmed up usually????
turmic 09-24-2013 01:18 PM
I thought that reverse has no syncros. That's why Brandon's method works.
the RIOT act 09-24-2013 02:42 PM
Mine will grind or just not go in at all 90% of the time I go to back out of my driveway. I pretty much always have to go forward a bit. I've read multiple threads on other WRX forums and really found nothing but little shift techniques like I do to make it easier. Nothing really that "fixes" the problem. Not gonna bother wasting my breathe at the dealership on this topic lol...so I just try to brush it off as one of the many cons of the WRX vs STI
BLAZE2099 09-24-2013 04:25 PM
Many, is being a touch harsh.
mosc 09-24-2013 04:33 PM
[quote=BLAZE2099;360442]Many, is being a touch harsh.[/quote]I'm finally rubbing off on Brandon ;)
Reverse doesn't have a syncro and it's straight cut. Double clutching it is not uncommon. That's depressing the clutch, putting the car in a gear , putting it back in neutral, releasing the clutch, depressing the clutch, putting it into reverse, then releasing the clutch to get going (well, backwards). You guys are spoiled. I drove a VW beetle for a while that I had to double clutch all but third gear. Don't buy Volkswagens...
the RIOT act 09-24-2013 04:54 PM
Ok ok...more than few...better Randy? Lol...
Mosc, I def can't help but agree on the many cons of a WRX vs STI. The list is quite large! But I knew what I was getting into anyways lol! If I were still a single/childless man I'd be sportin' an STI badge instead lol!
pzr2874 09-24-2013 06:13 PM
I have ALWAYS gone through 1-4 before putting it in reverse to prevent any kind od friction... helps me/mine.
Edit: When cold
man show 09-24-2013 08:15 PM
Sometimes my car won't go into reverse after it's been parked for a while. I have a feeling it's because the reverse gears are lined up perfectly tooth-to-tooth. If I put my car in neutral, leave my foot off the clutch, blip the gas, let the engine almost return to idle, press the clutch pedal, and try to move the shifter back into reverse, it will usually slide right in. It has pretty much done that since day one, so I assumed it was normal.
pzr2874 09-24-2013 08:32 PM
^ THAT'S what she said
Still need to mix the BS around in the gearbox....
turmic 09-24-2013 09:13 PM
Man, I'm just nailing my assumptions lately. First the radiator and now the reverse gear. WOO!! ROFL
thekamikaze kid 09-24-2013 10:08 PM
ive been driving stick on all my cars fer about 15 years. this has happened to me on all of them, no big deal! !Thumbs Up
