Removing a trans. 2002 WRX Impreza wagon - Subaru WRX Forum
post #1 of 19 Old 05-10-2013, 09:01 PM Thread Starter
I need a little help here. I searched for the subject but came up empty. New to the game here. I'm a Dodge Hemi guy but my sons' WRX has trans issues. We just had the trans replaced and I think the one we put in is bad. It was installed, driven for a few days and had to tow it home. Symptoms: Neutral, tires turn. In gear, tires do not turn. Seems normal. Start car up, put in gear and as the clutch is released, car stalls. Almost like the e brake is on. Even when rpms are increased, nothing. Did get it to go but heard massive grinding. (car is up on stands). Any ideas? Thanks.
G
p.s. Is there anything in the knowledgebase that can help me with the trans removal?
NotMySubie is offline
post #2 of 19 Old 05-10-2013, 10:45 PM
boo-key's Avatar
I can probably email the whole trans section out of the repair manual. It includes trans removal/install and some troubleshooting. Just let me know via pm if you want it. Good luck!
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #3 of 19 Old 05-11-2013, 03:16 PM
Either wrong trans or you installed something backwards...
post #4 of 19 Old 05-11-2013, 05:14 PM
boo-key's Avatar
Sent it!
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #5 of 19 Old 05-11-2013, 07:53 PM Thread Starter
Don't think either is possible. Car was driven for around 10 days before this happened. Thinking it is a clutch issue
post #6 of 19 Old 05-11-2013, 10:17 PM
Did you bleed the clutch master cylinder?
post #7 of 19 Old 05-12-2013, 09:06 AM
Like ps said, I would run through and check the easy stuff on the clutch first.... Bleed it, make sure the pedal is adjusted properly. How far off the floor does it engage?
If that checks out then maybe you did get a junk trans. Does the car shift when off? Run it through all the gears using the clutch while it's off, then you should be able to run through all the gears again without using the clutch since all the gears will have sync'd up with the input shaft. If it doesn't do that then something may be wrong.
Obvious question but worth asking, did you make sure to put fluid back in it after install?
post #8 of 19 Old 05-13-2013, 12:40 PM Thread Starter
I am assuming it was as the car was driven issue free for around 10 days. If low, is it just brake fluid? Please bare with me as I said, I am a Hemi guy so this is all new to me.
I'll go check the shifting situation rcrs and see what I find.
post #9 of 19 Old 05-13-2013, 01:36 PM Thread Starter
This might shed a little light on the issue. Just went out and ran it through what rcrs mentioned. Seems like it goes into every gear ok with the exception of 4th. Seems a little different. Anyway, I started the car and tried it. Stalls it out right of the floor. If I put the car in neutral and release the clutch, you can hear what I assuming is the throwout bearing grinding. Thoughts?
G
post #10 of 19 Old 05-13-2013, 09:31 PM
Throw out bearing installed backwards...???
post #11 of 19 Old 05-14-2013, 12:18 PM Thread Starter
That wouldn't allow the car to be driven for those 10 days though, would it? I wouldn't think so.
post #12 of 19 Old 05-15-2013, 07:22 AM
I'm leaning towards a bad gear in the trans. Have you tried starting it out in other gears besides first?
Btw, do you know the circumstances leading up to the latest failure to put it in it's current state? Flogging it or just cruising? 02-06 WRX's have pretty weak transmissions (as you know now).
post #13 of 19 Old 05-15-2013, 03:25 PM
Not true, I beat on mine hard for years before having any issues.
post #14 of 19 Old 05-15-2013, 09:09 PM
Unless you have a stupid amount of power, shifting smoothly is the key. If you bang the gears on any car, bad things will happen. Make sure you're completely in gear and the clutch is fully disengaged before you stomp the gas. Failure to take that extra moment could cost you several thousand dollars.
post #15 of 19 Old 05-16-2013, 08:22 AM
Not true,I beat on mine hard for years before having any issues.
I rest my case. There's a reason Subaru re-worked it for late 02-03, and even then look at the sheer # of 02-06 trans failures versus 08+. I beat the shit out of mine regularly too, we'll see how it holds up over time.
