Rear Differential Fluid Change - Subaru WRX Forum
post #1 of 13 Old 08-17-2007, 02:40 PM Thread Starter
I have seen many of you changing the fluid to Synthetics, BUT I don't understand what others are telling me about "synthetics rot / eat the silicone that lines the read diff housing" because there is no gasket. Is this just on the 07's ?? Any insight would be greatly appreciated.
post #2 of 13 Old 08-17-2007, 09:14 PM
i would just use what your owner's manual recommends
post #3 of 13 Old 08-18-2007, 12:21 AM
Fidrat's Avatar
Where did you hear this? I'd like to know. I just switched. I hope I didn't hurt anything.
Fidrat is offline
post #4 of 13 Old 08-18-2007, 10:02 AM Thread Starter
I've heard it from 2 shops out here. You know the "oil change" places. Not that I am running with what they said BUT 2 different places telling me the same thing is weird.
post #5 of 13 Old 08-18-2007, 10:13 AM
I've never heard that before..
post #6 of 13 Old 08-18-2007, 10:18 PM
mxboy15u's Avatar
mxboy15u is an unknown
I have used 2 different types of synthetic in my rear diff...and definately no leaks.
mxboy15u is offline
post #7 of 13 Old 08-19-2007, 01:54 AM
wolfracing's Avatar
wolfracing is an unknown
Send a message via Yahoo to wolfracing
I have tryed about every oil out there and have had no prob, i would use redline or royal purple.. I have had the most luck with these two oils.
Brandon
2002 subaru wrx stock....not for long
wolfracing is offline
post #8 of 13 Old 08-19-2007, 09:08 PM Thread Starter
But the guys told me that back in the day.... 02-05 WRX's had gaskets. Ours don't, they have this silicone sealant. Make sense ? All of you that are responding have older REX's. Royal Purple is what I want to put into it. 75-140 ?
post #9 of 13 Old 08-22-2007, 01:15 AM
wolfracing's Avatar
i use silcone on everything my mustangs and neon i have red ine in my wrx now
Brandon
post #10 of 13 Old 08-22-2007, 04:23 PM
I didn't put a new gasket on mine when I put the new fluid in, I used Silicone..
post #11 of 13 Old 08-22-2007, 07:30 PM
Yes, according to the repair manual, you are to use a liquid silicone sealant on the threads after the change.
post #12 of 13 Old 12-26-2007, 01:45 AM
kh15's Avatar
kh15 is an unknown
so has this issue been confirmed or is it false?
this is the first time im hearing about it and i know a TON of ppl that run synthetics in their diff and i was just about to but some redline in mine...
kh15 is offline
post #13 of 13 Old 12-28-2007, 03:39 PM
Most newer vehicles are switching to a FIPG (form in place gasket). Whether or not Subarus do this or not, I am not sure. It's the same concept as a normal gasket. Just easier and cheaper to implement. It's highly unlikely that any synthetics contain enough caustic substances to eat thru a seal like that.
