Really Cheap Shifter Bushings!!!! - Subaru WRX Forum
post #1 of 12 Old 08-30-2007, 05:11 PM Thread Starter
605wrx's Avatar
605wrx is an unknown
I found this and I thought it might be a typo or something but I called them and they said the price is correct, instead of paying 30-40 bux for shifter bushings these are $6 plus shipping.
http://ultrarev.com/product.php?productid=41587
605wrx is offline
post #2 of 12 Old 08-30-2007, 08:15 PM
Nose Nuggets's Avatar
im a firm believer in the "you get what you pay for" adage. however, it is JUST polyurethane.
pick em up and report back in 6 months. i would appreciate it.
Nose Nuggets is offline
post #3 of 12 Old 08-30-2007, 08:45 PM Thread Starter
605wrx's Avatar
will do
605wrx is offline
post #4 of 12 Old 08-31-2007, 12:46 AM
mystilexzero is an unknown
why do they look different compared to cobb or kartboys? was there always that big piece in the middle?
mystilexzero is offline
post #5 of 12 Old 08-31-2007, 12:47 AM
speedytang is an unknown
Send a message via AIM to speedytang
They are excellent and made by the Best name in the Urethane/Suspension business.
speedytang is offline
post #6 of 12 Old 08-31-2007, 01:08 AM
bigbadbuddha's Avatar
Images: 15
Energy Suspension is the best name in the urethane bushing business.... They would not put out a product that sucks..... I for one would get them just to see how they are...
My .02
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #7 of 12 Old 08-31-2007, 01:48 PM
VMethos is an unknown
Is that a set of both the front and rear shifter bushings? The price is crazy low for the fronts alone, but it doesn't specify front or rear, so I was just wondering.
Anyways, I'm going to place an order for them as well. I'll be replacing my clutch and flywheel in a week or two, so I'll swap these for the stock ones while I'm at it. (Don't worry, I know the mantra: "Stock Tranny, Stock Clutch. I'm not "upgrading" the clutch, just replacing it since mine started slipping at heavy loads in 4th and 5th recently, and it's been getting more frequent.)
VMethos is offline
post #8 of 12 Old 08-31-2007, 03:32 PM
how quick can yo swap shifter bushings. if this company is as good as you say, i have 10 bucks i cab throw at a nicer shift feel.
post #9 of 12 Old 08-31-2007, 05:13 PM
Well, I placed an order... the cheapest shipping option (UPS Ground) to PA was another $8.95. So the actual price is more around $15... which is still half the price of anything else I've seen. I'm still not sure whether it's a full set of front and rear bushings. If it is, then it's $45 cheaper than Kartboys full set, if not, then it's still $15 cheaper for the fronts.
Nose Nuggets: I'm not exactly sure how long it takes but everything I've read on the install is that it isn't hard and shouldn't take long at all. Probably between 20 minutes and an hour or so.
Once my set comes in, I'll let you know.
VMethos is offline
post #10 of 12 Old 08-31-2007, 05:31 PM
bitchn.
post #11 of 12 Old 08-31-2007, 07:01 PM
I ordered a set as well, the shipping was crazy, the lowest for me was 10 for ground. and if i wanted them overnight is was an extra 80 dollars.
nagyhead is offline
post #12 of 12 Old 09-13-2007, 09:15 AM
yeh. Just so everyone realizes... the default shipping option that was selected when I ordered was overnight airmail express or something, which was about $65 for me. So... be sure to change the shipping option to UPS ground or something more reasonable.
I just got the package in the mail yesterday. It's a solid, single piece front bushing. I believe the OEM is a single piece as well, while Kartboy and Cusco use two pieces (I think to make the install a bit easier, but I'm not sure). I'll try to find time this weekend or next to switch in this sucker and let you know how it is.
If I can't get the solid bushing installed easily, anyone know if cutting the bushing into two pieces (like Kartboy's or Cusco's) would be a problem?
VMethos is offline
