Go Back   WRX Forums > WRX Tech Forums > Drivetrain & Tranny
Old 07-20-2008, 11:06 PM   #1 (permalink)
Reputation: WCondoRX is an unknown
Proper RPM's ?
i have a 2006 wrx, cobb stage 2 (Accessport, turbo back exhaust)
I havent owned a wrx before, and im new to all this power (lovin it) -- what normal RPM's should i be shifting at? 1-2, 2-3, 3-4, 4-5 for every day driving and fuel efficiency... whats a cruising RPM for say 50 MPH ?
and what RPM's should i be shifting at to race someone or do more aggressive driving without damaging my tranny... say 0-60 ? for instance, what RPM should i be going to the next gear in?
help, thanks!
Old 07-21-2008, 06:48 AM   #2 (permalink)
For fuel efficecny you just basically need to shift gears before the turbo spools or you get deep into. As far as changing for spirited driving, as long as you arent slamming gears or dropping the clutc between you should be relatively fine. As far as keeping your speed and boost up its usually before redline. That point at where your boost is highest/before it starts to taper, us usually set upon in the tune. You just need to practice and pay attention to your ca and your driving habits to figure most of this out.
Old 07-21-2008, 12:58 PM   #3 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi is more helpful than not
In regards to racing someone, I'll usually shift as close to redline as possible without hitting the rev limiter. Typically around 7200 for my little 2.0. Not sure what the redline is on the 2.5s.
As newtothegame stated, as long as you aren't slamming gears or dumping the clutch you should be fine.
Daily driving, I usually shift around 3500 - 4000 rpms. I've been getting 23mpg with the VF34 and larger injectors when I do that. Problem is, I love boost. So my average mpg is only 19 - 20.
Old 07-21-2008, 03:38 PM   #4 (permalink)
The torque curve of your car determines the optimum shift points. Basically you shift when the next gear is making more torque at a given RPM than the gear you're currently in. On the 2.5L, this is ~5500 rpms and on the 2.0L it's ~6000rpms mattering on how it's tuned. Running it to redline or beyond is just putting extra ware on the engine and costing you time.
Engineers can't spell, sorry!
Old 07-21-2008, 08:23 PM   #5 (permalink)
sleepr's Avatar
Club Region: SoCal
Reputation: sleepr is an unknown
using this as a basis, you can "shorten" your shifts to save gas (shift lower than 5500rpms for example). Take this concept far enough and you'll be gleefully putting around like a non-turbo Impreza
70 to 100 faster than you can say "whoooossshh!"
Old 07-21-2008, 10:02 PM   #6 (permalink)
Gleefully? I wouldn't say that.
