-   -   Possible Center Diff Issues on 11' WRX (http://www.wrxtuners.com/forums/f69/possible-center-diff-issues-11-wrx-33437/)
horrorbiz 01-02-2013 05:47 PM
So I am having a strange issue with my car and I am curious if any of you have any thoughts / suggestions.
When turning tightly at slow speeds (either direction) my front end / center are making a strange knocking sound, almost like a wheel hop... but this only happens after driving on the highway for at least 15-20 miles. If I were to leave the car over night and then attempt to recreate the sound / feeling the next morning it would not happen.
After doing some research I started to think it was a center diff issue. Being that my car only has 34k on it and I don't abuse it, it seems unlikely. This morning I had Dent Sport check it out. They drained the fluid and everything seemed fine, no chunks of metal or other signs that the diff was shot. They checked out axles/etc and everything seemed fine.
They did however discover that the engine/tranny moved quite a bit and that the exhaust may have been hitting the driveshaft (and there were marks to show that). Anyway, they replaced my transmission mount with a Group N and thought the problem was solved. By the time I got home the noise was back...
I have an appointment with Subaru tomorrow morning—though I am a bit apprehensive due to my car being modified a bit (suspension, stage 1+, etc).
:confused:
pzr2874 01-03-2013 06:48 AM
What suspension pieces have you replaced?
Edit: found your intro thread.
Is it possible your RSB bushings are not lubed enough.... I'd start with that area. And the endlinks.
Vew 01-03-2013 11:48 AM
[quote=pzr2874;289200]
Is it possible your RSB bushings are not lubed enough.... I'd start with that area. And the endlinks.[/quote]
Knocking from RSB bushing usually only happens from bumps from my experience.
I have a similar knocking on my Outback the way you describe but it happens at any time I take a tight turn (slow speed). I just haven't cared to figure it out since it's a 13 year old car/beater.
Edit: It's probably your CV joint/axle. I didn't mention it earlier since I just replaced mine. Looks like it still happens with reman-ed axles which is what I replaced it with.
[url]http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/38922-popping-clicking-sound-when-turning-wheels.html[/url]
horrorbiz 01-03-2013 12:34 PM
I took it in to Subaru today. They are replacing the center diff under warranty. They even gave me a rental car!
pzr2874 01-03-2013 02:27 PM
Wow... nice.
horrorbiz 01-03-2013 06:49 PM
Subaru replaced the center diff... no more knocking/binding!
Vew 01-04-2013 09:40 AM
Glad to hear that was it and was fixed!
KD1CA 01-09-2013 08:59 AM
Awesome
