OEM Tranny Failures...POST EM UP - Subaru WRX Forum
post #1 of 8 Old 08-06-2009, 04:36 PM Thread Starter
04blusrt_4 is an unknown
Trying to get a real sense of how many guys have had their trannys barf up a gear set or snap an input shaft. Seems the rule of thumb or guidance mods and others give is, stock clutch with stock tranny.
Just want to make sure this isnt another of those old rules from the pre-04 era that has stuck even with the upgraded components.
Thanks guys.
04blusrt_4 is offline
post #2 of 8 Old 08-06-2009, 05:26 PM
Suspended
Boost Addict is more helpful than not
Thanks guys.
For what it's worth, I'm putting 334 ft lbs to the wheels on an 08 stock transmission. Clutch went out in ~10,000 miles (but saw about 12-14 visits to the drag strip). I replaced it with another OEM clutch + flywheel and it's been going well.
Stress and shock on the transmission is primarily through engagement, which is a sudden emission of power to the components. Once properly in gear, the factory gear sets have no problem in handling the strength.
I'm going to be tuning for some more power once I add my injectors, pump, equal length header, uppipe, and boost inlet hose... I'm afraid the oem clutch may begin slipping in higher gears, so I'm just a little nervous about stepping up to some kind of Stage 1 clutch.
Boost Addict is offline
post #3 of 8 Old 08-06-2009, 08:10 PM
I guess you're looking for a headcount for blown trannies? I destroyed mine 2 weeks after I got the car with one clutch drop. I knew nothing about subies then...
post #4 of 8 Old 08-07-2009, 12:07 AM
use the SEARCH button
post #5 of 8 Old 08-07-2009, 08:45 AM Thread Starter
Thanks, youre just pointing out my exact reason for creating this post. I couldn't find posts about tranny failures from upgraded clutches.
Try it...
post #6 of 8 Old 08-07-2009, 09:49 AM
tranny just went out (02 tranny blew. Believed aftermarket clutch)
Tranny go BOOM! (02 boom)
Flywheel/clutch problem (04 blew up)
tranny noise helppppp!! (03 boom)
I am now a member of Team Broken Tranny - Subaru WRX Forum: WRX Forums (lots of links to blown trannys here)
My car is dead..... (06 boom)
I only made 1 simple search and only looked at the first page of results. I know fastdak's BA (newer) tranny isn't on here and a bunch of other folks.
post #7 of 8 Old 08-07-2009, 12:59 PM Thread Starter
Guess i was looking for an 06 tranny broken from an aftermarket clutch.
Got any of those? I can find plenty of 02 "glass" tranny posts, not too many of what im lookin for.
post #8 of 8 Old 08-07-2009, 04:52 PM
nasioc.com has a plethora of em too. Please stop asking other people to do your research for you.
