My car Rattles...help!!! - Subaru WRX Forum
post #1 of 17 Old 12-10-2007, 08:46 PM Thread Starter
rsadarme's Avatar
rsadarme is an unknown
Thumbs up My car Rattles...help!!!
I have a 04 WRX wagon. Whenever my car is in first gear and i'm at a complete stop, my car shakes when i initailly begin to move forward. You can also hear something rattling as the car moves forward. The sound comes from the front to maybe the mid point of the car.
I'm thinking it could be the Flywheel and it may need resurfacing, but then again...i'm not sure. So if anyone may have an idea of what i may be. Give me your 2 cents.
Thanks for the help!
rsadarme is offline
post #2 of 17 Old 12-10-2007, 09:15 PM
IH8PVMNT's Avatar
IH8PVMNT is an unknown
yea sounds like you have some clutch chatter.... cut or replace flywheel and while your in there throw a new clutch on it
IH8PVMNT is offline
post #3 of 17 Old 12-11-2007, 06:07 AM
Longshot's Avatar
Stock trans = stock clutch for best performance. It's most likely your flywheel like said above, resurfacing it should eliminate that shake.
DTRacing Tuned
Longshot is offline
post #4 of 17 Old 12-11-2007, 06:15 AM
IH8PVMNT's Avatar
well yea defintley stock clutch if your stocker.... putting a heaver clutch in it will just put more stress on the transmission....
IH8PVMNT is offline
post #5 of 17 Old 12-11-2007, 02:23 PM
pearl_boxer's Avatar
pearl_boxer is more helpful than not
Glad everyone's in agreement here...this could have ended up in a messy battle like some of the other topics going on!Laugh!
Shaun
Protuned STI Limited #262
pearl_boxer is offline
post #6 of 17 Old 12-11-2007, 08:20 PM Thread Starter
rsadarme's Avatar
Well, since the fly wheel may need to be fixed, i was looking around for a new clutch, but i don't want to put to much stress on the tranny. I was looking at a Stage 1 Exedy Clutch, would that be something that i could replace the stock clutch with?
Any recommendations on clutches that are affordable, but are good for my situation?
rsadarme is offline
post #7 of 17 Old 12-11-2007, 08:46 PM
IH8PVMNT's Avatar
im not sure exactly what the stage 1 is from exedy... but i do know for a fact that exedy is the oem clutch.... stage 1 maybe an upgrade from the oem thugh
IH8PVMNT is offline
post #8 of 17 Old 12-12-2007, 01:35 AM Thread Starter
rsadarme's Avatar
So do you think that that clutch will stress out my tranny much?
rsadarme is offline
post #9 of 17 Old 12-12-2007, 06:29 AM
IH8PVMNT's Avatar
a heavier clutch will put more stress on your transsmision and drivetrain unless you have have some good power upgrades then its ok, if your stock id go with the stock clutch wich is exedy... im about to do mine. im gonna orcder the stocker
IH8PVMNT is offline
post #10 of 17 Old 12-12-2007, 06:41 AM
Longshot's Avatar
Go with an OEM clutch, it's your safest bet, plus your not going to see much of a difference other than clutch chatter even with the stage 1 exedy. Go OEM.
DTRacing Tuned
Longshot is offline
post #11 of 17 Old 12-12-2007, 08:49 AM
Thats the saying right there. Without an upgraded tranny, no need at all for an upgraded clutch. Unless of course you are trying to have a reason to replace the transmission later down the road.
post #12 of 17 Old 12-12-2007, 04:14 PM
b7g
b7g's Avatar
b7g is an unknown
Actually, i believe Subaru had to put in heavier flywheel sometime in in 2003, because a lighter flywheel was causing too much stress and effected driveability. Heavier flywheel makes the engine spin a fraction slower resuting in a smoother clutch pick up. I think if the clutch being replaced with stock, then its best to combine it with stock weight flywheel. That is what i am going to do...
Cheers...
drive = freedom
b7g is offline
post #13 of 17 Old 12-12-2007, 07:31 PM
IH8PVMNT's Avatar
Cheers...
i know they put a heavier one in but wasnt sure wich year... they put the heavier one in for people that complain about a wineing niose on down shift... it takes the stress off the trans and eliminate most of that niose....
IH8PVMNT is offline
post #14 of 17 Old 12-14-2007, 01:36 AM Thread Starter
rsadarme's Avatar
So overall, you think i should just go to OEM?
rsadarme is offline
post #15 of 17 Old 12-14-2007, 05:44 AM
Thats your best bet.
