lgt swap - Subaru WRX Forum
post #1 of 11 Old 12-26-2011, 07:55 PM Thread Starter
diesel paul's Avatar
diesel paul is more helpful than not
lgt swap
im going to order my gear set this week my question is i have two transmissions an 03 an a 04 the 03 was taken out because a failure the 04 is in the car which one should i do the swap into 03 i can take my time an rebuild it completely or the 04 kinda rush so i can put it right back in the 04 has no problems though is one better to do the swap into than the other oh an where is a good place to get bearings an synchros
2003 wrx hatch upgraded turbo three inch turbo back upgraded up pipe subaru upgrade intake
diesel paul is offline
post #2 of 11 Old 12-26-2011, 08:04 PM
Shouldn't matter which case you use. I believe the case is identical just the gears inside were a little different.
Kjott21 is offline
post #3 of 11 Old 12-26-2011, 08:20 PM
As far as synchros go, get in contact with the guys at andrewtech. They are pretty much the go to people for transmissions for these cars in the country. Not saying they are the only ones who know, or do them, but they are one of the most knowledgeable group of guys out there that are readily available to the public.
post #4 of 11 Old 12-26-2011, 08:35 PM Thread Starter
thanks guys
post #5 of 11 Old 12-26-2011, 08:41 PM
Not a problem. Good luck with everything. Be sure to let us know how it goes also.
post #6 of 11 Old 12-26-2011, 08:54 PM Thread Starter
ya i think ill break the 03 open an find out what needs to be fixed an start a list gotta get it ready for the 2.5 hybrid
post #7 of 11 Old 12-26-2011, 08:59 PM
In my opinion, depending on what you are going to do with the car, I'd suggest going with a set of 08+ gears. They make kits to allow them to be used in earlier transmissions. I believe they are around $1500 for everything you need. That's the route I am going...
post #8 of 11 Old 12-26-2011, 10:03 PM Thread Starter
i hear those are a little stronger but how much is the question i hear good about the lgt set but not to much about the 08 just kinda makes me nervous
post #9 of 11 Old 12-26-2011, 11:57 PM
I thought the LGT gears are the same as the 08+ WRX's?
Kjott21 is offline
post #10 of 11 Old 12-27-2011, 02:21 PM
They are.
post #11 of 11 Old 12-27-2011, 05:18 PM
Yeah, they are the same and Matt (basco) has said the bearings can only be had from the dealership. I'd get the kits that fit older transmissions to make sure you don't get stuck in any fubar moments that the kits fixed. Keith, do you have a link or more information on those kits?
Yes, I used some old military jargon
