Kartboy Short Shifter issue? - Subaru WRX Forum
post #1 of 9 Old 12-31-1969, 07:00 PM Thread Starter
Send a message via Yahoo to Santino
Hey guys,
I've had my shifter in for a week now, and I'm curious... My dad did the install, and when he put the new part in, he forgot how the old one was (which side in) so he took a guesstimate, so now I'm driving around, and I feel i really have to force it in, also, it's really easy to get into 2nd and 4th gears, but hard in 1st, 3rd, and 5th... Is it in incorrectly????? <IMG SRC="images/smilies/icon_confused.gif">
Santino is offline
post #2 of 9 Old 12-31-1969, 07:00 PM
Did he install the bushings as well? If it's just the shifter you can pull the console cover off and check. Make sure the shifter lever angles back from the bolt holding it on.
If he installed the bushings as well he might have simply over torqued the nut holding things together. This should loosen over time as the bushings wear in.
Gerlando is offline
post #3 of 9 Old 12-31-1969, 07:00 PM
mikeWRX's Avatar
If 1st, 3rd and 5th gear put the shifter REALLY close to the center console then he put the thing in backwards. Just remove the pivot bolt, turn the shifter 180 degrees and reinstall the pivot bolt.
mikeWRX is offline
post #4 of 9 Old 12-31-1969, 07:00 PM
Send a message via AIM to nekard
Does anyone else with the Kartboy shifter like it? Are the bushing hard to install?
2002 Silver WRX
Link Programmable ECU, TurboXS Stainless Steel Turbo-back exhaust, TurboXS BOV Type H, Black Samco Intercooler Hoses, 17x7.5" Rota Steel Grey Subzeros with Kumho Esta 235/45/R17 tiresPioneer Dehp9300
nekard is offline
post #5 of 9 Old 12-31-1969, 07:00 PM
mikeWRX's Avatar
I have it and love it. One of the best $125 mods you can do. The bushing install was easier than the shifter install IMHO. Took about 30 minutes to install the bushings. There is a writeup on this in the mods section of this site.
<font size=1>[ This message was edited by: mikeWRX on 2001-12-03 03:07 ]</font>
mikeWRX is offline
post #6 of 9 Old 12-31-1969, 07:00 PM
I'd agree that it's one of the best low cost mods you can do. Honestly I didn't feel as big a difference with the bushings as some people have, but it took 15 minutes MAX to install so why not...
Gerlando is offline
post #7 of 9 Old 12-31-1969, 07:00 PM Thread Starter
To answer, the top gears 1,3,5 don't put the shifter close to the console.... the lever is in correctly. I'm now in trouble because I can't shift into 5th gear on the first try... I have to attempt it, reset the lever to neutral, and then throw it into 5th again... UGH!!!! I'm gonna have to get it looked at, not sure what to do but that... Thanks for the input guys.
Santino is offline
post #8 of 9 Old 12-31-1969, 07:00 PM
Good luck Santino! Let us know what you find. My guess would be the shifter bushings have too much torque on them.
Gerlando is offline
post #9 of 9 Old 12-31-1969, 07:00 PM Thread Starter
Finally fixed it yesterday, and it turned out that the darn washer was on backwards, so it was hitting the linkage... Just got the wrench and turned it around with a little help from friends, and now I'm back to secure shifting, no worries about putting her in fifth! Thanks for all the support!
Santino is offline
« - | clutch shudder »
