Kartboy or Cobb questions - Subaru WRX Forum
 7Likes
post #1 of 21 Old 06-06-2013, 08:50 AM Thread Starter
richietables is an unknown
I've been reading about the shifter upgrades on this forum and other places. Is changing the front and rear bushings a one man driveway job? I'm pretty handy but really don't have access to a lift without paying for it. I wouldn't even mind just replacing the bushings before getting a new shifter just to see what things like firmed up.
Worth the hassle?
Thanks--
Rich
2005 WRX Wagon (1st owner)
1965 Malibu Convertible
2009 Corvette Coupe (Silver)
richietables is offline
post #2 of 21 Old 06-06-2013, 09:23 AM
Premium Member
the RIOT act's Avatar
I'd def do it all at once, and if you have some jack stands that should be enough room to do it in the driveway.
Kartboy it's def the way to go and if you're doing bushings I'd highly recommend getting a setup from TiC. It comes with the Kartboy shifter and bushings.
This...
http://turninconcepts.com/product_in...products_id=38
And this...
http://turninconcepts.com/product_in...products_id=89
Sent from AutoGuide.com App
richietables likes this.
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
post #3 of 21 Old 06-06-2013, 09:30 AM
09bluewrx's Avatar
09bluewrx is an unknown
I just did my kartboy shifter and bushings last weekend and took about an hour for the whole job. Jist used jack stands here
Sent from my DROID X2 using AutoGuide.Com Free App
09bluewrx is offline
post #4 of 21 Old 06-06-2013, 10:26 AM Thread Starter
OK, great info---
Seems awesome for under a $200 investment, so pull the trigger, huh?
Thanks
Rich
post #5 of 21 Old 06-06-2013, 11:11 AM
Premium Member
Pull it. There's no better setup I promise you 👍
post #6 of 21 Old 06-06-2013, 12:43 PM Thread Starter
Sweet, $180 shipped including tax, ordered it up from turninconcepts.com; both of the above recommended links.
Wish me luck with the install and I'll let you guys know how it turns out. Thanks for the info.
Cheers,
Richie
Rich
post #7 of 21 Old 06-06-2013, 02:58 PM
Premium Member
Def post your feedback. Glad we could help OP
post #8 of 21 Old 06-06-2013, 04:06 PM
O, and keep your arm/hand off the shifter.... Just my 2¢ whether you get a setup or not.
post #9 of 21 Old 06-06-2013, 04:59 PM Thread Starter
How come?
Rich
post #10 of 21 Old 06-06-2013, 05:05 PM
Originally Posted by richietables View Post
How come?
No need to put pressure on anything
post #11 of 21 Old 06-20-2013, 10:06 AM Thread Starter
I tried my very best, but in the end I was not able to do the install of the shifter and bushings on my '05 wagon. Drive shaft and exhaust were too much of a hurdle for me. I guess the point of no return was when I was unable to fit the new rear shifter bushing in with the kartboy bolts. I really tried and my hands are still scarred after a week. Disappointed, I sent the package back. Thanks for the good help here at the forum and please no cracks about how easy it is, I did my best. Had to cut the bait this time.
Rich
post #12 of 21 Old 06-20-2013, 10:29 AM
Premium Member
Could've kept it and had a shop install....
post #13 of 21 Old 06-20-2013, 03:31 PM
Brockton's Avatar
Those bolts are tricky because theres no wiggle room with the bushing being so stiff. I had to get one barely in, then worked for about 20 minutes trying to get the other one started, finally got it in a little bit, then spend another good 10 minutes working each one in a little at a time, then switch to the other one, back and forth then I finally got it in. Its a really good investment, I'm getting the short shifter once my paypal funds because available from selling my old turbo. Can't wait.
Brockton is offline
post #14 of 21 Old 06-20-2013, 05:48 PM
09bluewrx's Avatar
I used a swivel and a long ass extension and had to problems at all getting the two bolts in
post #15 of 21 Old 06-20-2013, 08:52 PM
Brockton's Avatar
A lot of people have trouble getting them started, those holes on the bushing are usually just barely out of line with the other holes, so you can start one but it usually takes some doing to start the next one. Common problem. Clearance isn't too big of a problem though.
Brockton is offline
