grinding in first - Subaru WRX Forum
post #1 of 13 Old 01-06-2008, 02:15 PM Thread Starter
Neils04 is an unknown
grinding in first
I picked up my 04 yesterday and when it goes into first at low speeds (parking lot) it grinds pretty hardcore. if im at a stop i have to hold the clutch in for a while before i put it in first. Im pretty sure the synchros are starting to take a shit but im just hoping that its a clutch cable or slave cylinder (im not even sure if its hydrolic or cable). any suggestions? and its got 60k on it, thanks!
Neil
Neils04 is offline
post #2 of 13 Old 01-06-2008, 03:56 PM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
It's probably the synchro- WRX trannies aren't the greatest..
D-Rock
Under constant pressure
SWFL Scooby is offline
post #3 of 13 Old 01-07-2008, 12:23 AM
I have read before, and heard that some people say its kind of normal in the older WRXs. I dont have a problem with that in my 07.
post #4 of 13 Old 01-07-2008, 12:33 AM Thread Starter
yea i actually read some stuff and found the early 04s have shitty tranys
Neils04 is offline
post #5 of 13 Old 01-07-2008, 02:38 AM
MilesFox's Avatar
MilesFox is an unknown
sounds like the clutch is dragging. either the fluid is low, it needs re-adjusted, or the clutch disc itself is delaminating.
or there could be an excess buildup of clutch dust in the flywheel. either of that or the pressure plate may be collapsed or has a broken spring
to prove your clutch is dragging, the reverse gear should grind under the same circumstance.
and if you turn the car off before puttint iti nto 1stor reverse it wont grind
have the clutch adjusted or at least look at the fluid or reservoir
and also, any subaru trans is not designed to be shifted into 1st while moving
MilesFox is offline
post #6 of 13 Old 01-07-2008, 02:47 AM Thread Starter
i dont mean to be a dick, but a suby tranny should be able to shift into first while moving. im not going 15 and trying to shove it in, i cant downshift into first to do a rolling stop or go into parking lots. i'll check the clutch 2morrow. Ill rack it and take a look around.
It does not grind in reverse, only first. i thought the clutch might be dragging but since it only happens in first it just seems like synchros. Im gonna take it back to the dealer if i cant figure it out 2morrow. thanks for the help guys!
Neils04 is offline
post #7 of 13 Old 01-07-2008, 03:54 AM
MilesFox's Avatar
well i guess you know what i meand. although all my advice and knowledge around here are going to be based from subarus you never heard of before
MilesFox is offline
post #8 of 13 Old 01-07-2008, 11:36 AM
Nose Nuggets's Avatar
if you do a double clutch downshift with an adequate blip it will go in smooth every single time. i highly doubt anything is wrong. do a search on double clutch downshifting i have a few posts here on the subject.
Nose Nuggets is offline
post #9 of 13 Old 01-09-2008, 12:02 AM Thread Starter
seeing as how it grinds at a dead stop right after you press the clutch in i figured the syncros. As did the tech at the dealer. Its still under the factory warranty so i dont have to rebuild the thing myself. Hes gonna rip the tranny out and order the snychros n what not. thanks for the help guys much appreciated!
Neil
Neils04 is offline
post #10 of 13 Old 01-09-2008, 12:21 AM
subarulover is an unknown
hey mine use to do that to but i just filled it up with some 80w-90 and she glides in now try it and hope it works just run it throught the gears acouple of times though so it can get all around in there
subarulover is offline
post #11 of 13 Old 01-11-2008, 02:20 AM Thread Starter
the dealer is going to replaced first and second gear along with the synchros. thanks for the input guys, i get it back on Monday!
Neils04 is offline
post #12 of 13 Old 01-11-2008, 05:05 AM
Hopefully that will solve your problem. Let us know the outcome.
post #13 of 13 Old 01-14-2008, 10:12 AM
skatman's Avatar
skatman is an unknown
i had the same problem in my 04 it has about 60k miles but i had to replace the hole tranny and clutch before i didnt get that problem
skatman is offline
