going into gear without the clutch - Subaru WRX Forum
post #1 of 6 Old 07-09-2005, 11:26 AM Thread Starter
imbeterthanu's Avatar
imbeterthanu is an unknown
ok, heres my problem. keep in mind it only does it every now and then. some times my car will go into 3rd gear whille the clutch is NOT pushed in. it usually happens in 3rd any ideas. and oh yeah, my clutch has a sqeak when i push it in. any one know?
thanks.
imbeterthanu is offline
post #2 of 6 Old 07-09-2005, 12:12 PM
WRXtreme's Avatar
That can easily be avoided by pushing in the clutch. Not to be an ass or anything, but why would you try to out it in gear without pushing in the clutch??
WRXtreme is offline
post #3 of 6 Old 07-09-2005, 12:26 PM Thread Starter
im not trying to force it into gear.
post #4 of 6 Old 07-11-2005, 12:59 AM
W0R2X's Avatar
Images: 11
W0R2X is an unknown
Send a message via AIM to W0R2X
answer to your question... hopefully
i dont know if i have the answer to you question exactly, but it is possible to drive a manual transmission car without using the clutch. when you are moving at the right speed, and revving at the right rpms, you can work with the synchros, and actually shift into the next gear. it sounds wierd, but its true. when my girlfriends clutch cable snapped, her clutch petal was stuck on the floor. i drove her car to a clutch shop without using the clutch, with no damage done.
since you clutch is working, you can start the car normally, and accel in first gear normally, but try this, when you are going about 20mph, at about 2000 rpms, release the gas slowly and gently move the stick into second gear. you might have to rev around 2500rpms, but it will go smoothly. for third gear, same thing but you have to be going about 28mph, and fourth gear same thing at about 38mph, fifth gear same thing at about 45 mph. it might be a little tough at first, but once you get the timing down, its simple. i hope this answers your question. good luck
W0R2X is offline
post #5 of 6 Old 07-11-2005, 12:50 PM
Nose Nuggets's Avatar
yeah its not to hard to drive without the clutch. in fact, in a dog rin transmission i never use the clutch. but thats something else entierly.
in my wrx i can esily get between 3rd 4th and 5th without the clutch, first to second and second to third require a little bit more fenagaling.
as long as its not grinding, its not doing anything bad.
Nose Nuggets is offline
post #6 of 6 Old 07-12-2005, 01:12 AM Thread Starter
ok kool thanks. so i dont have any thing to worry about good.
