Front diff shot...2WD or AWD - Subaru WRX Forum
post #1 of 50 Old 08-06-2012, 12:29 PM Thread Starter
Ridge10's Avatar
Ridge10 is an unknown
So I found out today that my front diff needs rebuilt. It will cost me around $1200. I know some people think is stupid to convert a WRX to a 2wd but Ive always had interest in it and now that my front diff is done, I have the option to either shell out some money or convert it. Has anyone else done this or thought about it? And if I sell my car would it scare alot of people away? I just cant decide.
-Derek
Ridge10 is offline
post #2 of 50 Old 08-06-2012, 01:03 PM
well the mod destroys your center diff and your rear diff can't handle all the torque from the engine so it will go soon after. So your choice is fix one now or have some 2WD fun and fix all three later.
post #3 of 50 Old 08-06-2012, 01:58 PM
Get it redone.
post #4 of 50 Old 08-06-2012, 05:52 PM
Hondafan's Avatar
I'm with both of these guys. I had a friend with an older eclipse that he thought he'd run 2WD, but ended up having to rebuild the whole transmission and rear end eventually (although I think the gears in the transmission were not due to him running RWD)
-Brad
Hondafan is offline
post #5 of 50 Old 08-06-2012, 06:01 PM
black beast2's Avatar
black beast2 is an unknown
Can't he just get a rwd tranny and a different rear end and run 2wd with no probs. like a ford or chevy set up or something like that?
I don't have to be mad to punch someone in the face!
black beast2 is offline
post #6 of 50 Old 08-07-2012, 08:34 AM Thread Starter
Ridge10's Avatar
I saw that I could put a Toyota tranny in but then i would still have to get a beefier rear end. This is the second time im taking the tranny out so Im thinking about just putting either a 04+ in or try this rwd set up.
-Derek
Ridge10 is offline
post #7 of 50 Old 08-07-2012, 08:46 AM
BoostinChick is a helpful contributing member
Why don't you find a diff from a wrecked vehicle or part out? Will cost you less than $1200....and yes, I think if you turn the car from it's original AWD to RWD it will ruin the resale value. One of the perks of the WRX is the symmetrical AWD system. Usually, you go RWD if you are taking it to the drag strip often.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #8 of 50 Old 08-07-2012, 09:15 AM
$1200 isn't all that bad IMHO.
Look for used parts as Sandra said.
post #9 of 50 Old 08-07-2012, 10:25 AM
Lets also mention that the car is balanced for power to the front wheels. It would oversteer horribly as a 2WD vehicle.
post #10 of 50 Old 08-07-2012, 11:17 AM Thread Starter
Ridge10's Avatar
So if I were to look for a used transmission, what would be the cheapest, strongest option?
-Derek
Ridge10 is offline
post #11 of 50 Old 08-07-2012, 12:00 PM
Wait, I thought your car had a bad front diff? That shouldn't require transmission replacement.
post #12 of 50 Old 08-07-2012, 12:02 PM
Pick one. Cheap or noticeably stronger.
post #13 of 50 Old 08-07-2012, 12:07 PM
Unless he meant center diff since that is inside the trans?
- Sandra
post #14 of 50 Old 08-07-2012, 12:12 PM
Search around, you can find a better, upgraded one (brand new) for cheaper than $1200.
post #15 of 50 Old 08-07-2012, 12:25 PM
The center diff in the WRX is pretty difficult to break. It's got more fragile components on either side of it and it's a mechanically simple part comparatively. The 02-07 WRX uses a straight 50/50 power split center diff.
