Which clutch to use with Kaaz gearset? - Subaru WRX Forum
post #1 of 2 Old 11-14-2004, 04:48 AM Thread Starter
Hi all,
I have quite a few mods going into my 04 wrx and it should be close to or over 350+ whp after it gets out of the shop in the next couple of weeks. I am also checking into having the Kaaz gear set put into the tranny. I figured I would get the transmission taken care of now instead of waiting until the gears go south.
What I wanted to know is what kind of clutch should I go with when using a gearset like that? After reading up on some of the problems with using lightened flywheels and the twin plate clutches I decided it would probably be best to stay away from that kind of stuff. However, I am not sure what kind of clutch to go with. Any help you guys could offer me would be very much appreciated. Thanks in advance.
jb0318 is offline
post #2 of 2 Old 11-14-2004, 09:18 AM
AZ-Scoob's Avatar
Send a message via MSN to AZ-Scoob
I would go with a slightly heavier pressure plate and a sprung hub disk, something like the Exedy organic or cerametalic clutch, should work fine, or go with the twin disk setup!
[I]"Winners never quit, quitters never win, those that never win or quit are idiots."[/I]
AZ-Scoob is offline
