-   -   clutch shudder or junk trans?.. (http://www.wrxtuners.com/forums/f69/clutch-shudder-junk-trans-33527/)
wick'd 01-27-2013 09:42 PM
So i feel i am experiencing clutch shudder with a side effect of a junk tranny. the issue: i have clutch shudder the car shakes really really,,, really bad and on top of that gears were whining and grinding like crazy. now they both seem pretty obvious but the grinding and whinning from the gears dont really fall under "clutch shudder/chatter" do they?.. anyones thoughts?
pzr2874 01-28-2013 05:52 AM
Have you drained any fluid to see if any shavings/chunks come out?
wick'd 01-28-2013 07:05 AM
Yes and both appeared
pzr2874 01-28-2013 08:32 AM
Need to rebuild the gears and might as well do the clutch/flywheel at the same time. There are plenty on nasioc. Might be in your interest to find the newest yr possible.
Good luck.
wick'd 01-28-2013 09:48 AM
i kinda plan on just keeping it as a daily driver so i think ill just get a used trans with low miles. and it already has a fidanza aluminum flywheel so i just need to replace the insert which is easy
wick'd 02-07-2013 08:35 AM
2 Attachment(s)
[ATTACH][ATTACH]6006[/ATTACH][/ATTACH]
Found the problem.
man show 02-07-2013 09:06 AM
Whoa! Those pics bring back memories... bad, bad memories :eek:
pzr2874 02-07-2013 10:34 AM
Well, you already knew...
Just you didn't WANT to know.... At least you have a plan.
mosc 02-08-2013 08:52 AM
Tis the fate of every 02 WRX. Try not to take it personally.
wick'd 02-18-2013 01:58 PM
now my bearing went out on the lsd so i gotta tear it apart again... gotta love it!
pzr2874 02-19-2013 05:34 AM
Damn..
