So through all my researching I found that on the 08+ models the clutch master is tac welded in a couple spots to the flexible fire wall. The brake master brace has been out for awhile and seems to make a difference. I noticed movement in my clutch master when the clutch is disengaged and re-engaged. So I looked across the web and found a brace made by Circuit Motorsports and was curious if anyone has used it and if it worked as advertised.
