Clutch Disengagement Problems - Subaru WRX Forum: WRX Forums
» Auto Insurance
Old 01-22-2013, 10:52 AM   #1 (permalink)
Reputation: 300zxturboftw is an unknown
So I tried NASIOC and the forums seem dead over there, so hopefully you guys may have an answer...
Installed a south bend clutch stage 4 endurance (kevlar) with a clutchmaster flywheel the other day and I'm having problems with clutch disengagement. The clutch is perfect when in gear, grabs nice and drives fine, but it seems I'm missing just a tiny bit of travel where I can't get into gear when the car is stopped and I'm in neutral. Car shifts fine through all gears when the car is off. It can be a bit notchy between 1st and 2nd and randomly some of the other gears because of the disengagement problem, but nothing as bad as when stopped as it's almost impossible to get into gear. Reverse always grinds...anyhow you get the point, full disengagement problems.
Checked:
Pulled boot and checked proper function between the TOB/fork and pressure plate. Looks fine and it clearly is working because I can drive the car and shift. Synchros seem to be fine as downshifting is super smooth.
Hydraulic system. Re-bled slave and it has full range of travel. Fork travels almost enough to release the little tension spring attached to it.
Fork has a little bit of play in it (technically throw out bearing does, but that's just how all pull type clutches are as it pulls out a little bit then pulls on the fingers of the pressure plate).
I'm stumped. Have you guys upgraded your hydraulic systems for higher clamp load pressure plates? This one I believe is around 2700-2800 lbs. I have an ACT in here before and it was fine, so it's not like I went from OEM to super high PP.
Any ideas?
Offline   Reply With Quote
Old 01-24-2013, 07:26 AM   #2 (permalink)
Reputation: RcrsWetDream is known to be trustworthy and helpful RcrsWetDream is known to be trustworthy and helpful
Have you adjusted the clutch pedal?
Old 01-24-2013, 11:13 AM   #3 (permalink)
That is a serious f-ing clutch man, sorry. You're out of my area
04 STi 16G powered lagless fun
04 WRX: SOLD
Old 01-24-2013, 08:45 PM   #4 (permalink)
detrails01's Avatar
Car: 05 WRX
Reputation: detrails01 is an unknown
Did you replace slave/throw out bearing when you installed new clutch?
Old 01-30-2013, 06:34 PM   #5 (permalink)
Reputation: turmic is a WRX expert worth listening to turmic is a WRX expert worth listening to turmic is a WRX expert worth listening to
What gears are you running?
