Clicking/Crunching noise - Page 2 - Subaru WRX Forum
post #16 of 37 Old 03-17-2012, 12:57 PM
Um...
I found those too about 3 months ago. That means your done sir. Game over. Who rebuilt the tranny? I hope it's under warranty. There are two options here
1. You currently have gears in your transmission sorely lacking teeth.
2. Those teeth stayed in the housing after the rebuild and have been grenading your current tranny, causing who knows how much damage.
post #17 of 37 Old 03-17-2012, 02:06 PM Thread Starter
Ridge10's Avatar
Ridge10 is an unknown
Awesome. Ill have to check up on the warranty. My mechanic that I usually go to sent it to someone to get it rebuilt. The guy took forever, and I still had some problems when I got it back, and now this.
So if its not under warranty, what should I do? I dont do much with trannys, so what could I upgrade in it went I have it out again?
-Derek
Ridge10 is offline
post #18 of 37 Old 03-17-2012, 09:25 PM
Wow, those are some nasty chunks. Whats your budget for a build and goals for the car?
post #19 of 37 Old 03-17-2012, 09:39 PM Thread Starter
Ridge10's Avatar
I just want a strong street car, nothing over-the-top. I dont have alot in the budget as of now, Im just slowly adding on.
-Derek
Ridge10 is offline
post #20 of 37 Old 03-17-2012, 09:43 PM
Look into the lgt gearset (i believe thats whats in the 08+ wrx also). They seem to be a good budget minded build option. Other wise things the like of albins, par and PPGs will run upwards of $5k and more.
post #21 of 37 Old 03-17-2012, 10:11 PM
Damn it...we need keith for this. He said there is a LGT kit for the previous gen gearboxes. Apprantley they made that kit to fix something that doesn't quite transition over smoothly without the kit. Grr....I forget, but I do know that Keith found something along those lines.
post #22 of 37 Old 03-17-2012, 10:12 PM Thread Starter
Ridge10's Avatar
Yeah, not looking to spend 5k on a transmission. I guess Ill have to start saving up.
So what exactly are the kits?
-Derek
Ridge10 is offline
post #23 of 37 Old 03-17-2012, 10:16 PM
Derek, not trying to tell you what to do, but your car has 150k and not getting any younger.
I think if it were me, I would be all over the tranny shop. And if that fails, than a stronger, stock like set to use as replacement.... Probably not a ppg set or something similar.
Just my .02
post #24 of 37 Old 03-17-2012, 10:18 PM
Found this: 05 LGT gears in 02 WRX trans - NASIOC
2005 LGT 1st/2nd gears in my wrx 5mt - i-Club
EDIT..another link:http://forums.nasioc.com/forums/show....php?t=1200164
and an FYI for others:FAQ: Comparison of Subaru Gear Sets, WRX, Legacy GT, STI RA, and more...
Just did a quick reading of each of these. Should have most the info you need to get started.
post #25 of 37 Old 03-17-2012, 11:10 PM Thread Starter
Ridge10's Avatar
Thank you, all of you. Yall help out alot!
-Derek
Ridge10 is offline
post #26 of 37 Old 03-17-2012, 11:12 PM
Its the Subie Love Derek...
post #27 of 37 Old 03-18-2012, 12:58 PM
Glad to help man. Let us know what you come up with and how things go. And good luck to you with it all.
post #28 of 37 Old 03-19-2012, 06:53 AM
Damnnnn Derek.... Save those teef. Sorry to hear about that as it's not a good feeling in the least.
post #29 of 37 Old 03-20-2012, 10:34 PM
So, I have to give credit where its due. Keith replied and gave me the link that he bought his LGT gears for his 02 WRX. He said this one has the kit for the previous gens. Well, here just read his quote.
Originally Posted by psinuse
Here is the kit that I bought for my car.
2005 - 2008 Legacy GT 1st - 4th Gear Set
Hope this helps you out bud. Anymore questions just let me know.
post #30 of 37 Old 03-21-2012, 10:00 AM Thread Starter
Ridge10's Avatar
So how good are the LGT gears? I mean, the 2002 tranny is notorious for being weak anyways, so would putting LGT gears in would be better then doing a tranny swap with a better year?
And I havent really done research on transmissions so I dont know a lot about them, but why does the set come with 1st-4th if I have a 5 speed?
-Derek
Ridge10 is offline
