Clicking/Crunching noise - Subaru WRX Forum
post #1 of 37 Old 03-12-2012, 09:35 AM Thread Starter
Ridge10's Avatar
I have a 02 WRX with 144k, bought it at about 124ks and rebuilt the tranny, new front axles, and sensors. The car has had this clicking/crunching noise before and after the tranny rebuild while I turn, I was told its the throw out bearing, but is that right?
-Derek
Ridge10 is offline
post #2 of 37 Old 03-12-2012, 10:30 AM
Never been in a WRX with a bad thowout...
BUT
Clicking/crunching is NOT a throwout sound.
TO's have a whirrling sound in my experience
Tell me this, does it make the same noise with the clutch in AND out? In Neutral of course
post #3 of 37 Old 03-12-2012, 09:38 PM
Is the steering wheel at full lock out to the side or is it just partial?
post #4 of 37 Old 03-13-2012, 09:10 AM Thread Starter
Ridge10's Avatar
I guess its not the throw out because the clutch, i dont think, has anything to do with it because it happens when Im already in gear going while turning. It happens in partial steering.
-Derek
Ridge10 is offline
post #5 of 37 Old 03-13-2012, 03:42 PM Thread Starter
Ridge10's Avatar
I was driving today, and it seems like it only makes a noise while Im powering through a corner in first or second gear...
-Derek
Ridge10 is offline
post #6 of 37 Old 03-13-2012, 04:00 PM
mazzanic's Avatar
While shifting ??? If it was then maybe synchros?? If its crunching between gears thats my thought. But maybe i read post wrong
Follow up:: im an idiot didnt read post lol
mazzanic is offline
post #7 of 37 Old 03-13-2012, 04:07 PM
Like a tie rod click???hmmmm
post #8 of 37 Old 03-13-2012, 04:39 PM
Is it like a binding only around corners? Does the car get jumpy?
When my front dif went out, When turning it clicked hard and you could feel it.
post #9 of 37 Old 03-13-2012, 06:36 PM Thread Starter
Ridge10's Avatar
I got the car at 124k and it was in not-so-good condition. Had the transmission rebuilt because the syrcos were going out, but its always been jumpy. In 1st and 2nd and if its rolling in gear and I give it gas. Its not jumpy around corners more if I was going straight. If I really get on it when going around a corner at slow speeds it makes that clicking sound.
-Derek
Ridge10 is offline
post #10 of 37 Old 03-15-2012, 04:03 PM
it's been a while, but this happened in my old '79 Subaru, it was the (if memory serves correctly)CV joints on the front wheels. Mine wore because the rubber boots tore and grit got inside. So, check those...
deadwhale is offline
post #11 of 37 Old 03-16-2012, 01:20 PM Thread Starter
Ridge10's Avatar
Ok. Im pretty sure he changed the cv axles but Ill check and I changed my tranny fluid for the first time since the rebuild and I found a couple pieces of teeth. I guess Ill just have to keep a eye on it.
-Derek
Ridge10 is offline
post #12 of 37 Old 03-16-2012, 01:29 PM
Hold up.
You changed the fluid AFTER the rebuild and you found teef in there?
post #13 of 37 Old 03-16-2012, 02:57 PM Thread Starter
Ridge10's Avatar
Yes. I changed the fluid after about 20k on the rebuilt tranny.
-Derek
Ridge10 is offline
post #14 of 37 Old 03-16-2012, 11:57 PM
Hmmm
have pics ?
post #15 of 37 Old 03-17-2012, 09:26 AM Thread Starter
Ridge10's Avatar
-Derek
Ridge10 is offline
