-   -   Clicking/Crunching noise (http://www.wrxtuners.com/forums/f69/clicking-crunching-noise-32172/)
Ridge10 03-12-2012 09:35 AM
I have a 02 WRX with 144k, bought it at about 124ks and rebuilt the tranny, new front axles, and sensors. The car has had this clicking/crunching noise before and after the tranny rebuild while I turn, I was told its the throw out bearing, but is that right?
pzr2874 03-12-2012 10:30 AM
Never been in a WRX with a bad thowout...
BUT
Clicking/crunching is NOT a throwout sound.
TO's have a whirrling sound in my experience
Tell me this, does it make the same noise with the clutch in AND out? In Neutral of course
turmic 03-12-2012 09:38 PM
Is the steering wheel at full lock out to the side or is it just partial?
Ridge10 03-13-2012 09:10 AM
I guess its not the throw out because the clutch, i dont think, has anything to do with it because it happens when Im already in gear going while turning. It happens in partial steering.
Ridge10 03-13-2012 03:42 PM
I was driving today, and it seems like it only makes a noise while Im powering through a corner in first or second gear...
mazzanic 03-13-2012 04:00 PM
While shifting ??? If it was then maybe synchros?? If its crunching between gears thats my thought. But maybe i read post wrong
Follow up:: im an idiot didnt read post lol
BLAZE2099 03-13-2012 04:07 PM
Like a tie rod click???hmmmm
Chase 03-13-2012 04:39 PM
Is it like a binding only around corners? Does the car get jumpy?
When my front dif went out, When turning it clicked hard and you could feel it.
Ridge10 03-13-2012 06:36 PM
I got the car at 124k and it was in not-so-good condition. Had the transmission rebuilt because the syrcos were going out, but its always been jumpy. In 1st and 2nd and if its rolling in gear and I give it gas. Its not jumpy around corners more if I was going straight. If I really get on it when going around a corner at slow speeds it makes that clicking sound.
deadwhale 03-15-2012 04:03 PM
it's been a while, but this happened in my old '79 Subaru, it was the (if memory serves correctly)CV joints on the front wheels. Mine wore because the rubber boots tore and grit got inside. So, check those...
Ridge10 03-16-2012 01:20 PM
Ok. Im pretty sure he changed the cv axles but Ill check and I changed my tranny fluid for the first time since the rebuild and I found a couple pieces of teeth. I guess Ill just have to keep a eye on it.
pzr2874 03-16-2012 01:29 PM
Hold up.
You changed the fluid AFTER the rebuild and you found teef in there?
Ridge10 03-16-2012 02:57 PM
Yes. I changed the fluid after about 20k on the rebuilt tranny.
pzr2874 03-16-2012 11:57 PM
Hmmm
have pics ?
Ridge10 03-17-2012 09:26 AM
2 Attachment(s)
[attach]5605[/attach]
[attach]5606[/attach]
