Brand new 5 speed having trouble getting in first gear. - Subaru WRX Forum
post #1 of 5 Old 11-10-2007, 11:11 AM Thread Starter
subydude101 is an unknown
I put a new 5 speed tanny in my 02 wrx and it's feels like something is stoping it form going in gear. But if u let the car roll forward alitlle it goes right into gear. Has anyone else had this problem I have had a couple buddies tell me that subaru has been having promblems with the new tranny not wanting to go in first gear.
subydude101 is offline
post #2 of 5 Old 11-10-2007, 11:51 AM
mine has that problem going into reverse, but as far as it going into first I have no problems there.
Is your fluid level good? i put redline shockproof in my trans and it seemed to help with getting it into reverse
nagyhead is offline
post #3 of 5 Old 11-10-2007, 01:33 PM
IH8PVMNT's Avatar
IH8PVMNT is an unknown
sounds like it might be a synchronizer drop the drain plug and check for small
metal grindings or fileings..... prior owner might have missed and grinded some gears wich would damage the synchros
um... didnt realize the part that saiid NEW so yea disgaurd....
IH8PVMNT is offline
post #4 of 5 Old 11-11-2007, 02:11 AM
TwoCobras is an unknown
Pulled the 02 5-spd, yesterday, put in new gears today. The Redline had turned to a blue/green gritty paste on nearly all gears and had begun to plug up the oiling holes. We had the use of an industrial parts cleaner that heats to nearly 200 degrees but it still didn't get some of the crap off. Rags, brake clean, and elbow grease. I will never, ever, again use anything but a standard synthetic transmission fluid. Lucky for me, we cracked the case and were able to clean everything inside before there was any real drama. The only casualties were the two bearings on the final shaft. The races were pitted and scarred, and the needle bearings were discolored (the green sludge had plugged up their ability to oil).
On the plus side, I now have a stock 02 WRX 5-spd input shaft and 1-4 gears, including the H gear for sale. All are in excellent to very good condition.
TwoCobras is offline
post #5 of 5 Old 11-11-2007, 12:40 PM
What Redline did you have in there? The MT-90?
nagyhead is offline
