Blown Tranny . . . Suggestions for new one??? - Page 2 - Subaru WRX Forum
post #16 of 22 Old 08-30-2007, 12:31 PM
arm0313 is an unknown
I read around a little and I from what I saw it looks like at some point subaru started installing stock RA gaer sets in the 03's. Is that the same thing as the Version 6 STI RA gear set?
arm0313 is offline
post #17 of 22 Old 08-30-2007, 04:25 PM
no. They installed RA gear WIDTH in the middle of 03 on but they're not the same gears.
post #18 of 22 Old 08-30-2007, 04:29 PM
Very helpful mosc, Thank you.
arm0313 is offline
post #19 of 22 Old 08-31-2007, 02:38 AM
bigbadbuddha's Avatar
Images: 15
I run a JDM Liberty (Legacy) STI 5 speed tranny with a 4:11 final drive love the tranny and holds well for me....
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #20 of 22 Old 09-06-2007, 10:18 AM
Kylar is an unknown
Originally Posted by DrewLL66 View Post
"For a 1-4 PPG Syncro transmission (straight or helical cut) the built price is $5221 with your core. This price includes the gears, labor, install parts and all new syncros.
For a 1-2 PPG Syncro with your OEM 3/4/5 transmission, the built price is $2991 for pre-03 transmissions, and $3091 for post-03 transmissions with your core. This price includes our gears, labor, and install parts. For all new syncros add $250 to the price."
I'm no math genious but that is $2000 difference. That is a direct quote from andrew. I called him today and its 2k difference for a full ppg setup vs a 2 gear setup.
I'm sorry, but am I the only one that sees this as highway robbery. For that ridiculous price I would buy a sti 6 speed and do the swap.
How much hp can those gears hold compared to a 6 speed tranny?
Kylar is offline
post #21 of 22 Old 09-06-2007, 10:19 AM
Kylar is an unknown
Do you know how much hp these are good for? I could get one for $900
Kylar is offline
post #22 of 22 Old 09-06-2007, 02:31 PM
Im not sure if you know what all it takes to swap a STI 6 speed into the WRX. Its more than just the tranny. Theres basically the entire rear-end of the car, and the DCCD to install. I guess if you could afford that set up and then put it in yourself it wouldnt be that bad, but that seems a little involved. I have heard that the PPGs are good to 800+HP. Not sure. I have only seen one WRX with that output and it was only on a dyno, so not sure what tranny he was running. But Im sure the PPGs could hold what you would throw at it, its your axles that would go next I would imagine.
