Blew my 07 trans tonight - Page 14 - Subaru WRX Forum
post #196 of 209 Old 11-21-2011, 08:44 AM
You guys are backwards on your ratios.... Lower number = taller, higher number = shorter... The 3rd gens have a shorter final drive but all of our individual gear ratios are are higher.. I'd say just because of the final drive we still have quite a bit shorter gear set than the 07 and earlier.
I'd also wager the final drive is what's keeping the 08+ gears from breaking as often. Somebody will eventually find their breaking point, but it's obviously much higher than the previous years.
And John, yeah that 5th gear is slightly shorter, so you'll see a bit higher crusing rpm at the same speeds as the stock gears... BTW how does that longer first gear feel? From my math you should be able to do about 43 mph at 6500 rpm's vs the stock ratio letting you about 38.
post #197 of 209 Old 11-21-2011, 12:32 PM Thread Starter
I haven't tested out any gear to the max yet since I still have the non-synthetic break-in fluid in my box. So far, I have only driven several hundred miles, so I'm still trying to take it easy until 1,000-1,500, at which point I'll switch to the Andrewtech cocktail and romp on it a little. I think I'm still on cloud 9 about having my car back to notice those kinds of differences, but I'll try to pay attention and see if I notice anything.
Originally Posted by basco View Post
One of my friends in FL actually was the first person in the US to break a set of PPG gears, and one of my co-workers with a 600+whp WRX shattered 2nd gear on his PAR box
Well, it's a good thing I don't live in FL or have 600+ whp
But yeah, I realize they can break just like anything mechanical. I just feel a bit more confident that they'll be able to handle the abuse they're given.
post #198 of 209 Old 11-21-2011, 12:55 PM
You will be fine until you snap your axles and then replace them, lol. Glad to hear you are enjoying the car John. How about a whine? How noticable is it with your gears? With mine its not too noticable at low speeds, so you really might not notice it yet. Just kind of curious.
post #199 of 209 Old 11-21-2011, 10:21 PM
Damn it, your right. I always get gear ratios messed up. Its always the opposite of what you think it is. Lower is taller and higher is shorter.
Here have some more useful info thanks to www.cars101.com I added the STI ratios to the mix.
For 2002-2007 WRX:
5 speed manual- 1st- 3.454, 2nd-1.947, 3rd- 1.366, 4th- 0.972, 5th- 0.738, final is 3.9 for 2002-2005 and 3.7 for 2006-2007
For 2008-2011 WRX:
5 speed manual; 1st 3.166, 2nd 1.882, 3rd 1.296, 4th 0.972, 5th 0.738, final 3.900
For 2004-2006 STI
6 speed manual; 1st: 3.636, 2nd: 2.375, 3rd: 1.761, 4th:1.346, 5th:0.971, 6th: 0.756, final 3.9, reverse: 3.545
For 2007-2011 STI
6 speed manual; 1st: 3.636, 2nd: 2.235, 3rd: 1.521, 4th:1.137, 5th:0.971, 6th: 0.756, final 3.545, reverse: 3.545
Last edited by turmic; 11-22-2011 at 10:29 PM. Reason: Ken found what I over looked... :p
post #200 of 209 Old 11-21-2011, 11:50 PM Thread Starter
Yep, they whine. It sort of sounds like a jet, but it's not obnoxiously loud by any means. I've only heard straight cut gears in person on several occasions and every time, I could hear them clearly across the parking lot. Mine aren't that loud. I hear them the most in 1st through 4th, but when I'm cruising in 5th, the HKS cat back drowns them almost completely out
post #201 of 209 Old 11-21-2011, 11:50 PM
Here have some more useful info thanks to Subaru Research Site- specs, prices, options, 2012, 2011, 2010, 2009.. Outback, Legacy, Forester, Impreza, Tribeca, BRZ, XV I added the STI ratios to the mix.
For 2002-2007 WRX:
5 speed manual- 1st- 3.454, 2nd-1.947, 3rd- 1.366, 4th- 0.972, 5th- 0.738, final 3.700
For 2008-2011 WRX:
For 2004-2006 STI
For 2007-2011 STI
Actually Final on the 02-05 is 3.9 and on the 06-07 it is 3.7
Kjott21 is offline
post #202 of 209 Old 11-22-2011, 05:06 AM
No it's 3.14
post #203 of 209 Old 11-22-2011, 09:06 AM
BoostinChick is a helpful contributing member
May I ask, why the Andrewtech cocktail? Will that be sufficient enough for how large the gears/teeth are? Only reason I ask is, Andrewtech pushed me to use Neo. Albeit, this could be because this is what PAR recommends. So, did Albins or IAG recommend anything?
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #204 of 209 Old 11-22-2011, 10:11 AM Thread Starter
Both Albins and IAG recommended the Andrewtech cocktail independently. Plus, I'm already hooked on the smurf blood
post #205 of 209 Old 11-22-2011, 10:27 PM
Nice catch Ken. I did miss that tid bit of info.
John: I would like to hear your gears and then compare them to basco's. lol....I bet Matt's are loud if you can hear them over his race car noises.
post #206 of 209 Old 11-22-2011, 11:23 PM Thread Starter
Well, we need to set up that meeting at mosc's place one of these days and maybe I'll even let you drive it
post #207 of 209 Old 11-22-2011, 11:30 PM
No it's 3.14
I only remembered it was different because people were complaining that the taller rear end put more stress on the gears with the 06/07's.
Kjott21 is offline
post #208 of 209 Old 11-23-2011, 10:57 PM
Yeah, I just completely forgot about it. The discussion hasn't be brought up lately.
Why does it have to be philly as the meeting place? LOL and I haven't driven a 5 spd in a while. Plus mosc would just drool over my engine bay.
post #209 of 209 Old 11-23-2011, 11:26 PM Thread Starter
I might drool a little too...
