Originally Posted by wrx54
Do I get this done or do I live in the garage for a week? How much do people charge for labor? Can I watch? What parts are the absolute best? Do I need a new flywheel? What about a master cylinder? How do I mod my ECU so I can really try out this new part? Do I really have to granny shift for 4000 miles after installation? What is Stage II?
Help?
you are asking alot of questions that the answers are easily available by using the search feature...but to help you out a little
1. this is up to you, how mechanically inclined are you. if you have done decent mechanical work before i would say tackle it yourself. there is a step by step guide on how to do it available on nasioc. ( the one which i used) but beware that a lack of mechanic tools can make this task very very difficult, and for some people impossible.
2. any good mechanic shop will usually chage about 100$ an hour for labor. the clutch is quoted to be a 7-8 hour job. Subaru quoted me for around $1,200 to $1,500. a private shop quoted me at 700$ to 800$ without parts.
3. depends on the shop
4. "absolute best" is relative, the absolute best clutch for a drag racing car is different than one for a tuner street car. furthermore, many of these absolute best parts would just be a waste of money as your car might not even reach their potential. On top of this, it is important to take into account you weak stock transmission. the rule of thumb is "stock tranny, stock clutch." exedy sells a OEM replacement that works great.
5. you would either need to get a new flywheel, or to get yours resurfaced (approx. 40$). I personally put a lightened flywheel in.
6. answer your own question, if your clutch wore down due to regular wear and tear, or abuse, you just need to replace the clutch. if it is wearing down too quickly and your not sure why, it is a good idea to troubleshoot, as your problem may be your cylinder.
7. there are a few ways to mod out your ecu. look up these three. cobb accessport, tatrix cable + romraider, delta utec. a tuning shop with an awd dno can also write you a custom map.
8. 4000 miles? thats seems like alot. usual break in for a stock style clutch is 800-1000 city miles. This means 1000 mile sof stop and go traffic situations. With easy smooth shifts during this time. it is ok to drive on the highway, but these miles wont count toward your total.
9. stage 2 is one of the "stages" you cars engine and thus performance can be at. stage 1 would be an ecu tune, while stage 2 is an ecu tune with a downpipe. when installing the clutch, the exhaust has to come out, so it would be easy to throw on a downpipe while you are there... however, make sure you are able to hold back your right foot, as you can quickly burn through that new clutch with the added power
