Adding 5MT trans fluid - Subaru WRX Forum
post #1 of 5 Old 05-09-2009, 02:39 PM Thread Starter
ajskladanek's Avatar
ajskladanek is an unknown
Send a message via AIM to ajskladanek
Just a simple quick question. Is it ok to mix different brands of oil in the transmission. I was checking my fluid levels and what not today and i noticed that my trans fluid is not full. Its about half way between full and low. I am not sure what brand oil is in there now. my car is an 04 wrx completely stock if that affects the answer. Thanks for your time and input.
new and improved.
ajskladanek is offline
post #2 of 5 Old 05-09-2009, 03:11 PM
It will be fine if you top it off with another brand.
nagyhead is offline
post #3 of 5 Old 05-09-2009, 06:19 PM Thread Starter
cool thanks that is all i needed to know.
new and improved.
post #4 of 5 Old 05-09-2009, 10:21 PM
boo-key's Avatar
If you are going to buy some to top it off you might as well get 3 or 4 more quarts and change it. It is really easy.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #5 of 5 Old 05-09-2009, 11:19 PM
Here's some food for thought: recommended transmission and rear differential fluid changes are every 30,000 miles. How many miles are on your car? If you're anywhere near there and you're unsure if the fluid has ever been changed, you might want to consider changing the fluid completely like boo-key bear mentioned. Just make sure you have the correct tool to remove the drain plug - for example, on my 2007 WRX, I needed a T-70 Torx bit. I don't know for sure what the earlier models require, but don't make the mistake I made and use a T-60, because you might end up stripping the bolt and be forced to destroy it with a set of vice grips trying to get it off Good thing replacement drain plugs are cheap.
