5th gear crunches in gear at high speed? - Subaru WRX Forum
post #1 of 6 Old 09-15-2007, 11:17 PM Thread Starter
robbiedwrx is an unknown
What should I do to fix this? What gear box oil is standard? and what GB oil is good/ better for my 04 wrx 5speed with 100,000km...
robbiedwrx is offline
post #2 of 6 Old 09-16-2007, 01:01 AM
nick4592's Avatar
Well....you gear box may just need some fixing at that mileage...but I use Redline shock proof and it really helps with syncro problems
nick4592 is offline
post #3 of 6 Old 09-17-2007, 07:00 PM
Nose Nuggets's Avatar
100K MILES? have you pulled the gearbag yet and looked at the gears? 100K on any trans is substantial. you might be past "i need the uber gear lube blend" threads.
Nose Nuggets is offline
post #4 of 6 Old 09-17-2007, 08:16 PM
Jave's Avatar
Jave is more helpful than not
100k kilometers.
but I am confused are you shifting into 5th really really fast or you are driving say 150kph and gently shift into 5th?
▼SbiΣ Mi▼
Jave is offline
post #5 of 6 Old 09-18-2007, 04:20 AM Thread Starter
Im shifting genltly into 5th at 100kph and above!!
post #6 of 6 Old 09-18-2007, 12:04 PM
Jave's Avatar
syncro or gear is out/going out. WIth aggresive driving I get the same ting going into 4th, that is my syncro though
▼SbiΣ Mi▼
Jave is offline
