-   -   5speed (http://www.wrxtuners.com/forums/f69/5speed-32402/)
blazinbret 04-23-2012 04:43 PM
5speed
So my tranny went out. Was wondering if anyone knows good place to find used one at a decent price. its a 02 with 5 speed MT and stock beside exhaust and intake
Sent from my LG-P925 using AutoGuide.com App
rex2002 04-23-2012 06:53 PM
i bought mine on ebay. got it for super cheap.i had to replace the input shaft seal,but other than that it was great. shift smooth in all gears.
oldspower71 04-24-2012 05:06 PM
You gonna keep it stock? That will play a huge role in what you want to do.
BLAZE2099 04-24-2012 08:08 PM
[url=http://www.car-part.com]Car-Part.com--Used Auto Parts Market[/url]
NicWRX 04-24-2012 08:50 PM
I have killed 2 stock 5speeds in the past year. I am currently talking to a place called Moore Performance about having one built. Either buy used or get one built.
spc2125 04-24-2012 09:14 PM
So obviously this is an example of how the stock 02 wrx trannys are weak.
Anything you can do to avoid the tranny from going?
possibly an upgraded clutch?
turmic 04-24-2012 09:49 PM
Upgrading the clutch adds more stress to the gears. So, thats not going to save the trans...it will add more wear and tear.
spc2125 04-24-2012 10:27 PM
[quote=turmic;279325]Upgrading the clutch adds more stress to the gears. So, thats not going to save the trans...it will add more wear and tear.[/quote]
what can help it?
mosc 04-24-2012 10:48 PM
[quote=spc2125;279329]what can help it?[/quote]
Ripping off the turbo?
You can help it by driving better and shock loading less. You can also buy stronger gears and put them in. You can also replace the part entirely with something much stronger.
most transmission failures have one of if not all of the following causes:
1) Shock loading / Abuse
2) "upgraded" clutches
3) larger than stock turbos or >94 octane fuel maps
sleepr 04-25-2012 12:57 AM
No "launching" and smooth (still can be strong) applications of power. I have had absolutely no problems with my transmission...
EvilOopa 05-04-2012 08:51 PM
This kind of goes along with this thread, but what different years of 5mt transmissions will fit my BugEye WrX? Sorry: Mine is an '03.
brfatal 05-04-2012 09:03 PM
'02-'04.
mosc 05-04-2012 09:46 PM
[quote=brfatal;279722]'02-'04.[/quote]
Why stop there? Up to 07 should work fairly painlessly.
brfatal 05-04-2012 10:32 PM
[quote=mosc;279724]Why stop there? Up to 07 should work fairly painlessly.[/quote]
I was speaking direct plug and play. Sometime during the MY04 build run they switched axle fitment so he would need to replace those for a mid-'04 and up transmission.
BoostinChick 05-07-2012 11:19 AM
Not only that, but difference between a push vs. pull style transmission in 06-07.
