4-5 gears grind - Subaru WRX Forum
post #1 of 7 Old 04-28-2009, 03:08 AM Thread Starter
AOD_SNOWMAN's Avatar
AOD_SNOWMAN is an unknown
Send a message via MSN to AOD_SNOWMAN
4-5 gears grind
Sup guys, been a long time since I posted in here. Well, a little issue has come up. Recetly my 4th and 5th gears have been having a slight grind to them while shifting into gear at high RPMs. However at low RPMs and just cruising it doesn't grind. I did a clutch replacement a while back, and everything was fine, and here recently its been acting up. Only under heavy accelleration and high rpms it has a grind only in 4-5th gears Any ideas?
Thanks guys
AOD_SNOWMAN is offline
post #2 of 7 Old 04-28-2009, 06:57 AM
JimmyJ is an unknown
My car does the same exact thing except in only 4 gear, any leads yet? I'm thinking I need to change my tranny fluid.
JimmyJ is offline
post #3 of 7 Old 04-28-2009, 09:03 AM
Yeah, definitely try changing your transmission and rear differential fluids. It's pretty easy to do by yourself with simple hand tools and even if your gears don't grind, it will still make a world of difference. If that doesn't work, I'd take it to a shop and have it looked at before it leaves you stranded somewhere.
post #4 of 7 Old 04-28-2009, 10:23 AM
boo-key's Avatar
+1 for tranny fluid change. If that dont work it could be your synchro's.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #5 of 7 Old 04-28-2009, 02:33 PM Thread Starter
Well, I replaced the fluid when I installed a new clutch. And the fact it acts up only at high rpm, puzzles me..but I might try that again what should I use for new fluid?
post #6 of 7 Old 04-28-2009, 04:06 PM
wagonracer's Avatar
Uncle Scotty's cocktail has fixed the same issues for me two different cars. Search it, or just buy it from GrimmSpeed :: Subaru Racing Parts
wagonracer is offline
post #7 of 7 Old 06-10-2009, 05:48 PM Thread Starter
Wagonracer you rock man!!! I finally got to changing my tranny fluid. The cocktail from Grimmspeed is absolutely phenomenal. Made a whole worlds difference in the sound, smoothest shifting ever. I recommend it for every subaru owner. And anyone with a WRX should have this cocktail in thier tranny. I noticed an immediate difference and so will you!!!!!
