STi 6 speed swaps are always cool, but there is a laundry list of other parts you'll need to complete the job. That's why I opted for a set of upgraded 5 speed gears - direct replacement. Albins is a competitor of PPG and they make gears that are just as strong, if not stronger. IAG can hook you up with them if you're interested
Here's a detailed thread (with before and after pics) from when my trans was rebuilt at IAG:
Blew my 07 trans tonight
$316.00 labor for the trans teardown
$474.00 labor for the rebuild
$4,142.51 for the Albins 1-5 gearset (after a 10% discount because I had to wait so long)
$83.95 for an SPT trans mount
$30.00 for a set of Kartboy trans crossmember bushings
$39.50 labor to install the mount/bushings
$7.99 for a 3" 2-bolt exhaust gasket
$19.00 for a turbo-to-downpipe gasket
$75.00 for the resurfaced flywheel
$5.00 for miscellaneous exhaust hardware
$48.40 for Motul 75w90 gear oil
My rebuild was a touch over $5k.
