1st gear has troubles need help asap! - Subaru WRX Forum
post #1 of 6 Old 07-16-2013, 12:17 PM Thread Starter
Durtydyl is an unknown
So I'm planning on buying a 2002 wrx wagon with 170,000 miles on it for 6000 my only concern was when I was rolling and trying to get down into first gear it would grind so hard and wouldn't get into the gear until i was at a complete stop is this a frequent problem on these with the transmission or what do you think it is? Also is that even a good deal I guess they put a new engine in it about a year ago?
Durtydyl is offline
post #2 of 6 Old 07-16-2013, 12:20 PM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
This is pretty common on the higher mileage 5 speed transmissions.
Changing the transmission Fluid to fresh Subaru Extra S or your preferred "Cocktail" can help depending on how bad it is.
PRO Import Tuners
PROImportTuners is offline
post #3 of 6 Old 07-16-2013, 01:16 PM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
I thought the Wrx trans wouldn't allow you to get into first untill almost completely stopped. Someone correct me if I'm wrong.
Sent from AutoGuide.com App
06_hawk_eye is offline
post #4 of 6 Old 07-16-2013, 01:23 PM
Premium Member
arewmors's Avatar
I'd agree with that. I drove a 5 speed g5 and it did the same thing, wouldn't go into 1st until just about stopped. My WRX now will grind if I try to put it in reverse while still moving as well, never tried 1st there's no need. Probably a safety thing so you don't put it in 1st at a higher speed on accident. Why would you need to put it 1st gear before you're almost stopped?
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
post #5 of 6 Old 07-16-2013, 02:57 PM
I believe you have to be below like 8mph or so before, I have heard of people doing it a 15mph, but it's all hear say...use you brakes to slow down, you'll be thankful in the end because brakes are cheaper than a trans. Yeah i'd also HIGHLY recommend changing the gear oil in the trans and the rear diff as these items get over looked all the time.
post #6 of 6 Old 07-16-2013, 11:50 PM
That's normal. There is nothing wrong. You're not supposed to be able to downshift from anything but a rolling start.
