-   -   1st gear has troubles need help asap! (http://www.wrxtuners.com/forums/f69/1st-gear-has-troubles-need-help-asap-36833/)
Durtydyl 07-16-2013 01:17 PM
So I'm planning on buying a 2002 wrx wagon with 170,000 miles on it for 6000 my only concern was when I was rolling and trying to get down into first gear it would grind so hard and wouldn't get into the gear until i was at a complete stop is this a frequent problem on these with the transmission or what do you think it is? Also is that even a good deal I guess they put a new engine in it about a year ago?
PROImportTuners 07-16-2013 01:20 PM
This is pretty common on the higher mileage 5 speed transmissions.
Changing the transmission Fluid to fresh Subaru Extra S or your preferred "Cocktail" can help depending on how bad it is.
06_hawk_eye 07-16-2013 02:16 PM
I thought the Wrx trans wouldn't allow you to get into first untill almost completely stopped. Someone correct me if I'm wrong.
arewmors 07-16-2013 02:23 PM
[quote=06_hawk_eye;323849]I thought the Wrx trans wouldn't allow you to get into first untill almost completely stopped. Someone correct me if I'm wrong.
[color=gray]Sent from [url=http://www.autoguide.com/mobile]AutoGuide.com App[/url][/color][/quote]
I'd agree with that. I drove a 5 speed g5 and it did the same thing, wouldn't go into 1st until just about stopped. My WRX now will grind if I try to put it in reverse while still moving as well, never tried 1st there's no need. Probably a safety thing so you don't put it in 1st at a higher speed on accident. Why would you need to put it 1st gear before you're almost stopped?
psinuse 07-16-2013 03:57 PM
I believe you have to be below like 8mph or so before, I have heard of people doing it a 15mph, but it's all hear say...use you brakes to slow down, you'll be thankful in the end because brakes are cheaper than a trans. Yeah i'd also HIGHLY recommend changing the gear oil in the trans and the rear diff as these items get over looked all the time.
brfatal 07-17-2013 12:50 AM
That's normal. There is nothing wrong. You're not supposed to be able to downshift from anything but a rolling start.
