06 clutch replacement - Subaru WRX Forum
post #1 of 4 Old 11-02-2007, 10:08 AM Thread Starter
my clutch is startin to slip and i need to replace it. do the 02-05's use the same clutch at the 06-07's? the reason i ask is cause i wanted to see if i could buy the oem exedy clutch kit from gripforce.com but the description says its for 02-05 wrx's. thanks for any help guys
achavez is offline
post #2 of 4 Old 11-02-2007, 04:26 PM
I'm pretty sure you can NOT use that clutch kit, as it's for the 2.0 L of the 02 through 05 WRX's. Since the 06s and up are on the 2.5 engine block, I have a feeling there could be fitment issues. This is just my guess, but I'd wait on buying the clutch kit until you are absolutely certain it'll fit and work. You could probably call gripforce up and see if they have a kit for the 2.5L WRX's.
Best of luck.
VMethos is offline
post #3 of 4 Old 11-02-2007, 10:54 PM
05WRXRally's Avatar
If thats the case maybe you can use a 04/05 STi OEM clutch
When the green flag drops...the bullshit stops
05WRXRally is offline
post #4 of 4 Old 11-03-2007, 12:27 AM
robert.lshoc's Avatar
do not use a 2.0 clutch when u have a 2.5
robert.lshoc is offline
