-   -   06 clutch replacement (http://www.wrxtuners.com/forums/f69/06-clutch-replacement-20921/)
achavez 11-02-2007 10:08 AM
my clutch is startin to slip and i need to replace it. do the 02-05's use the same clutch at the 06-07's? the reason i ask is cause i wanted to see if i could buy the oem exedy clutch kit from gripforce.com but the description says its for 02-05 wrx's. thanks for any help guys
VMethos 11-02-2007 04:26 PM
I'm pretty sure you can NOT use that clutch kit, as it's for the 2.0 L of the 02 through 05 WRX's. Since the 06s and up are on the 2.5 engine block, I have a feeling there could be fitment issues. This is just my guess, but I'd wait on buying the clutch kit until you are absolutely certain it'll fit and work. You could probably call gripforce up and see if they have a kit for the 2.5L WRX's.
Best of luck.
05WRXRally 11-02-2007 10:54 PM
If thats the case maybe you can use a 04/05 STi OEM clutch
robert.lshoc 11-03-2007 12:27 AM
do not use a 2.0 clutch when u have a 2.5
