Hey guys, my 05 sti is having some problems with the dccd controller. My car starts and the DCCD light will be on. Then I tried using the manual controller and the check engine light came on and the cruise control light, and the dccd light that is green started flashing as well.... I looked online and found that it could be fuses from abs system or dccd controller fuse. Both fuses are good. Any ideas?
Is the DCCD switch itself bad? It does happen (saw it first hand). Try and find someone else that will let you just swap DCCD's for a few minutes and see what that results in. If the same thing happens idk what the issue could be, if it works fine, then you will just need to get a new switch.
