-   -   04 wrx grinds 4th (http://www.wrxtuners.com/forums/f69/04-wrx-grinds-4th-37873/)
wrximpreza04 08-13-2013 02:54 PM
04 wrx grinds 4th
Hey guys,
My 4th gears grinds but not always, depends if i double clutch or what speed I am going. I would like to get a newer tranny anyways. Does anyone know where I can get one or Should i rebuild my old one?
Thanks,
Nathan21 08-13-2013 04:08 PM
go buy an sti tranny and get that extra great, that is what I would do if I am buying a new tranny but that is my 2c
man show 08-13-2013 04:24 PM
Albins and PPG make replacement gears for your WRX 5 speed trans that are just as strong, if not stronger than STi gears. There are also other companies that make slightly less expensive aftermarket gears. Also, keep in mind that if you go with an STi 6 speed, you'll need to upgrade your hubs from 5x100 to 5x114.3, which means you'll need new wheels if yours aren't already dual-drilled, as well as different differentials and a small collection of other goodies to make everything work properly.
Here's another fun fact: stock vs. stock, the WRX 5 speed gear ratio is faster 0-60 mph than the STi 6 speed. The top end is another story though ;)
BoostinChick 09-02-2013 07:36 PM
[quote=man show;337697]Albins and PPG make replacement gears for your WRX 5 speed trans that are just as strong, if not stronger than STi gears. There are also other companies that make slightly less expensive aftermarket gears. Also, keep in mind that if you go with an STi 6 speed, you'll need to upgrade your hubs from 5x100 to 5x114.3, which means you'll need new wheels if yours aren't already dual-drilled, as well as different differentials and a small collection of other goodies to make everything work properly.
Here's another fun fact: stock vs. stock, the WRX 5 speed gear ratio is faster 0-60 mph than the STi 6 speed. The top end is another story though ;)[/quote]Just some correction here..you [B]do not[/B] need to replace the hubs to do the 6-speed install. Some folks choose to because you pretty much need every other drivetrain part anyway - trans, rear diff, possibly subframe and axles (dependent on year trans you go with), etc.
When was the last time you replaced the trans fluid? Did you try Subaru Extra-S? I would go with a fluid change (~$50-80) if you haven't done it in awhile vs. shopping for a trans.
BLAZE2099 09-02-2013 08:56 PM
[quote=BoostinChick;349714]
When was the last time you replaced the trans fluid? Did you try Subaru Extra-S? I would go with a fluid change (~$50-80) if you haven't done it in awhile vs. shopping for a trans.[/quote]
^ this
man show 09-03-2013 08:48 PM
[quote=BoostinChick;349714]Just some correction here..you [B]do not[/B] need to replace the hubs to do the 6-speed install. Some folks choose to because you pretty much need every other drivetrain part anyway - trans, rear diff, possibly subframe and axles (dependent on year trans you go with), etc.
Thanks, didn't realize you could keep the 5x100 hubs. Good info! !Thumbs Up
brfatal 09-03-2013 09:49 PM
A little late, but change your transmission fluid and see if you get different results.
turmic 09-03-2013 10:40 PM
The 04 STI came with 100x5 hubs...so, there is a way to do it.
