-   -   02 WRX will not always shift into first gear (http://www.wrxtuners.com/forums/f69/02-wrx-will-not-always-shift-into-first-gear-33304/)
serenityzippo 11-23-2012 11:12 PM
So i got a 02 wrx and went out driving for a little bit today. A cold day of around 27 degrees. I was accelerating quickly and when to shift into second when my foot slipped off the clutch. There was a bit of grinding so i settled down and put it in 3rd. Later down the road i had to stop at a stop light and found i could not put it into 1st gear period. car off or on. clutch in or out. started going in second and got to where i was going.
I let the car sit for an hour to hour and a half and went to leave. It shifted into first just fine. Not really sure whats up that it would not shift when it is warmed up but will when it is cold. Any thoughts? Also is this something that should be professionally checked out?
Thanks
rex2002 11-24-2012 02:09 AM
if i were you i would def take it to a shop. i also had some issues during the cold weather and ending up blowing out second gear. not cool. i also would drive it as little as possible to you figure it out. plus check your fluid and make sure its at the right level
